Please I need help to interface the Pololu Serial motor controller this one Pololu Dual Serial Motor Controller (kit) , I have try everything .
Thanks.
Thanks.
OK this is what i have :
// Arbot v1.0 (dist 90 - 400)
byte derF[] = {128,0,5,50};
byte izqF[] = {128,0,7,50};
byte derB[] = {128,0,4,50};
byte izqB[] = {128,0,6,50};
int dist;
byte lop,lopp;
byte reset = 8;
pinMode(reset,OUTPUT);
digitalWrite(reset,HIGH);
void giraDer()
for (lop=0; lop<4; lop++)
Serial.print(izqF[lop]);
delay(20);
Serial.print(derB[lop]);
delay(20);
void giraIzq()
Serial.print(derF[lop]);
delay(20);
Serial.print(izqB[lop]);
delay(20);
void forward(byte vel)
for (lopp=0; lopp<3; lopp++)
Serial.print(derF[lopp]);
Serial.print(vel);
delay(20);
Serial.print(izqF[lopp]);
Serial.print(vel);
delay(20);
void backward(byte vel)
Serial.print(derB[lopp]);
Serial.print(vel);
delay(20);
Serial.print(izqB[lopp]);
Serial.print(vel);
delay(20);
int distancia()
int dist;
dist = analogRead(0);
return(dist);
delay(53);
void loop() //this is just for test
forward(127); //goes forward 10 sec
delay(10000);
for (byte vel=127; vel>19; vel--) // then slows down
forward(vel);
delay(10000);
forward(0); //brakes
delay(5000);
giraDer(); // an then turn to right
delay(5000);
Try byte derF[] = {128,0,3,50};
That should drive the first motor forwards if I read correctly.
3 days ago I discover it was in ONE motor mode, working fine.
Thanks.
