need help to jump over a part of program inside loops
Hi, Guys!
I'm testing a program, and I'd like to jump over a part, but using GOTO was unsuccesfull... Can You recommend me a good solution?
... void setup() { ... // Setup the LCD ++++++++++++++++++++++ myGLCD.InitLCD(); ... myGLCD.clrScr(); // ... // I WOULD LIKE TO JUMP OVER THE NEXT LINES //
myGLCD.setColor(97,178,94); myGLCD.fillRect(0,0,150,100); myGLCD.setColor(255,255,102); //élénksárga myGLCD.print("Tbelso:",20,10); myGLCD.print("oC",70,50); //ADAT 30,50-től myGLCD.setColor(65,81,10264); myGLCD.fillRect(150,0,300,100); myGLCD.setColor(255,255,102); //élénksárga .... myGLCD.print("LADA VAZ 21925",100,240); delay(1000); //
// I WOULD LIKE TO CONTINUE PROGRAMMING FROM HERE
void loop() { .... }
Thanks: rcph
Under what conditions would you like to "jump over" the section of code ? If you never want to execute that section of code then delete it or comment it out
I note that despite the thread title the code that you want to "jump over" is not in a loop
Hello, Bob!
Yes, I know the commenting method, but I'd like to make it easier...
I tried to use GOTO, but my attempt was unsuccesfull:
... goto NEXT;
.... NEXT: ...
I did something wrong, but I don't know, what?
Easier than commenting the code ? Delete it
OK, thanks.
If you do not want to delete it :
[u]A Guide to Commenting Blocks of Code in the IDE[/u]
1 - select the block of code to be commented 2 - press Ctrl and / on the keyboard
Thank You very much!
