Hi Team,
please i need your help in detecting why my code is not sending the current battery voltage value of in the sms alert received. Please kindly find attached my code and picture of the sms alert recieved, once the threshold is reached, the gsm module sends an sms to my phone number but it does not contain the value of the current battery voltage; it only displays 0.0V in the text. please help me:.....................................
Arduino_Sim800_Battery_Limit_Alert.ino (1.8 KB)
@isaacjohnsong007 You should always post code using code tags, as more people will see it and can help you. An attachment won't work with phones and others won't be bothered to download the code and place it in a folder.
#include <SoftwareSerial.h>
#define LIMIT 23.0 // Change it to your favoured value in Celsius.
#define NUM_SAMPLES 10
SoftwareSerial GSMSerial(9, 10);//Connect 9 to TX of GSM and 10 to RX of GSM
int sum = 0;
unsigned char sample_count = 0;
float voltage = 0.0;
// Setting up the Arduino.
GSMSerial.begin(19200); // Setting the baud rate of GSM Module
Serial.begin(19200); // Setting the baud rate of Serial Monitor (Arduino)
delay(10000);
GSMSerial.print("ATE0\r");
GSMSerial.print("AT+CMGF=1\r");
GSMSerial.println("AT+CNMI=2,2,0,0,0\r");
Serial.println("Finished Setup Section");
void SendMessage(){
GSMSerial.println("AT+CMGF=1"); //Sets the GSM Module in Text Mode
delay(1000); // Delay of 1000 milli seconds or 1 second
GSMSerial.println("AT+CMGS=\"+2347064309xxx\"\r"); // Replace x with mobile number
GSMSerial.print("POP Battery Bank Voltage is Low: ");// The SMS text you want to send
GSMSerial.print(voltage,1);
Serial.println(voltage);
GSMSerial.println(" V");
GSMSerial.println((char)26);// ASCII code of CTRL+Z
delay(1000); //give module time to send SMS
GSMSerial.println();
Serial.println("Message Sent");
delay(5000); // give module time to send sms
// Arduino does this forever.
while (sample_count < NUM_SAMPLES){
sum += analogRead(0);
sample_count++;
delay(10);
float voltage = (((float)sum / (float)NUM_SAMPLES *30)/1024.0)*1.2;
Serial.print("Battery Voltage is :");
Serial.print(voltage, 2); //Reading the voltage to 1 decimal point
Serial.println("V");
delay (500);
sample_count = 0;
sum = 0;
if(voltage<=LIMIT){
SendMessage();
delay(3600000); // wait for 1 Hour
You have a global float variable
And then again a redeclared local variable with scope confined to loop()
Which variable to you think the function is sending? Why did you redeclare voltage in loop?
See this reference on scope.
https://www.arduino.cc/en/pmwiki.php?n=Reference/Scope
Thanks so much for bringing this to my attention. I corrected the double declaration and now i can recieve the value of the battery voltage alongside the sms.
#define LIMIT 23.0
int sum = 0;
float voltage;
delay(10000);
void SendMessage(){
GSMSerial.println("AT+CMGS=\"+232706430xxxx\"\r"); // Replace x with mobile number
GSMSerial.print(voltage,2);
GSMSerial.print(" V");
sample_count++;
delay(10);
delay (500);
sample_count = 0;
sum = 0;
if(voltage<=LIMIT){
SendMessage();
