I got it to work with this hack. Open to a cleaner solution
/* Knock Sensor
This sketch reads a piezo element to detect a knocking sound.
It reads an analog pin and compares the result to a set threshold.
If the result is greater than the threshold, it writes
“knock” to the serial port, and toggles the LED on pin 13.
The circuit:
- connection of the piezo attached to analog in 0
- connection of the piezo attached to ground
- 1-megohm resistor attached from analog in 0 to ground
created 25 Mar 2007
by David Cuartielles http://www.0j0.org
modified 30 Aug 2011
by Tom Igoe
This example code is in the public domain.
// these constants won’t change:
const int ledPin = 10; // led connected to digital pin 13
const int knockSensor = A0; // the piezo is connected to analog pin 0
const int threshold = 5; // threshold value to decide when the detected sound is a knock or not
// these variables will change:
int sensorReading = 1; // variable to store the value read from the sensor pin
int ledState = HIGH; // variable used to store the last LED status, to toggle the light
pinMode(ledPin, OUTPUT); // declare the ledPin as as OUTPUT
Serial.begin(9600); // use the serial port
// read the sensor and store it in the variable sensorReading:
sensorReading = analogRead(knockSensor);
// if the sensor reading is greater than the threshold:
if (sensorReading >= threshold) {
digitalWrite(ledPin, HIGH);
delay(50);
digitalWrite(ledPin, LOW);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
