Need help to optimize code
Board - ESP32 UNO D1
Controlling Dc motor via Alexa . Browser(wifi) , Bluetooth and using door sensors to stop at start/end
Pins -
Motor controller
D16-IM1
D17-IN2
Door sensors
Sensor 1 - 12
Sensor 2 - 25
Libraries used - AsyncTCP .fauxmoESP,BluetoothSerial,WiFi
#include <Arduino.h>
#include <WiFi.h>
#include "BluetoothSerial.h"
#define RELAY_PIN_1 16
#define RELAY_PIN_2 17
const int sensor1 = 12;    // set the sensor1 pin mode
const int sensor2 = 25;    // set the sensor2 pin mode
WiFiServer server(80);
int state;
#include "fauxmoESP.h"
#define SERIAL_BAUDRATE 115200
#define WIFI_SSID "WIFI_SSID"
#define WIFI_PASS "WIFI_PASS"
#define LAMP_1 "open door"
#define LAMP_2 "close door"
fauxmoESP fauxmo;
// Wi-Fi Connection
void wifiSetup() {
  // Set WIFI module to STA mode
  WiFi.mode(WIFI_STA);
  // Connect
  Serial.printf("[WIFI] Connecting to %s ", WIFI_SSID);
  WiFi.begin(WIFI_SSID, WIFI_PASS);
  // Wait
    Serial.print(".");
    delay(100);
  // Connected!
  Serial.printf("[WIFI] STATION Mode, SSID: %s, IP address: %s\n", WiFi.SSID().c_str(), WiFi.localIP().toString().c_str());
    server.begin();
BluetoothSerial SerialBT;
    SerialBT.begin("ESP32test"); //Bluetooth device name
    pinMode(sensor1, INPUT_PULLUP); // set the sensor1
    pinMode(sensor2, INPUT_PULLUP); // set the sensor2
  Serial.begin(SERIAL_BAUDRATE);
  wifiSetup();
  // LED
  pinMode(RELAY_PIN_1, OUTPUT);
  digitalWrite(RELAY_PIN_1, LOW);
  pinMode(RELAY_PIN_2, OUTPUT);
  digitalWrite(RELAY_PIN_2, LOW);
  fauxmo.enable(true);
  // Add virtual devices
  fauxmo.addDevice(LAMP_1);
  fauxmo.addDevice(LAMP_2);
  fauxmo.onSetState([](unsigned char device_id, const char * device_name, bool state) {
    Serial.printf("[MAIN] Device #%d (%s) state: %s\n", device_id, device_name, state ? "ON" : "OFF");
    if ( (strcmp(device_name, LAMP_1) == 0) ) {
      // this just sets a variable that the main loop() does something about
      Serial.println("RELAY 1 switched by Alexa");
      //digitalWrite(RELAY_PIN_1, !digitalRead(RELAY_PIN_1));
      if (state) {
        digitalWrite(RELAY_PIN_1, HIGH);
    if ( (strcmp(device_name, LAMP_2) == 0) ) {
      Serial.println("RELAY 2 switched by Alexa");
      if (state) {
        digitalWrite(RELAY_PIN_2, HIGH);
  fauxmo.handle();
    state = !digitalRead(sensor2);
    if (state == HIGH){
  state = !digitalRead(sensor1);
    if (state == HIGH){
 WiFiClient client = server.available();   // listen for incoming clients
  if (client) {
   Serial.println("New Client.");
    String currentLine = "";
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        if (c == '\n') {
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println();
            // the content of the HTTP response follows the header:
            client.print("Click <a href=\"/H1\">here</a> to open-16
            client.print("Click <a href=\"/L1\">here</a> to turn motor off.
            client.print("Click <a href=\"/H2\">here</a> to close-17
            client.print("Click <a href=\"/L2\">here</a> to turn motor off.
            client.println();
            // break out of the while loop:
          } else {    // if you got a newline, then clear currentLine:
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
        // Check to see if the client request was "GET /H" or "GET /L":
        if (currentLine.endsWith("GET /H1")) {
        if (currentLine.endsWith("GET /L1")) {
        if (currentLine.endsWith("GET /H2")) {
        if (currentLine.endsWith("GET /L2")) {
    // close the connection:
    client.stop();
    Serial.println("Client Disconnected.");
    if (SerialBT.available()) {
    byte data;
    data = SerialBT.read();
    if (data == '1') //press '1' turns the LED on
    else if (data == '2') //press '2' turns the LED off
     if (data == '11') //press '1' turns the LED on
    else if (data == '22') //press '2' turns the LED off
code became too big with libraries attached.
How much do you have to save?
ROM or RAM?
If you're short of RAM, you could make better use of F() macro.
I am not sure
Newbie here :smiley:
Arduino: 1.8.5 (Windows 7), Board: "ESP32 Dev Module, Default, QIO, 80MHz, 4MB (32Mb), 921600, None"
Archiving built core (caching) in: C:\U...\core_espressif_esp32_esp32_PartitionScheme_default,FlashMode_qio,FlashFreq_80,FlashSize_4M,UploadSpeed_921600,DebugLevel_none_f7764ada9df3fcdb4d00ee644c78b17f.a
Sketch uses 1401142 bytes (106%) of program storage space. Maximum is 1310720 bytes.
Global variables use 66284 bytes (22%) of dynamic memory, leaving 228628 bytes for local variables. Maximum is 294912 bytes.
Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
Error compiling for board ESP32 Dev Module.
