Need Help to Read and Write on SD Card - UNO
Hi, this is my first post in the forum, so if you need me to change something please let me know :slight_smile:
I am working with an Arduino UNO in Proteus. I want to record and playback (in a CSV file) the movement of two servos that I am controlling with a Joystick.
To select the SD file that I want to either Read or Write I use a few Pushbuttons and a LCD Display with an I2C Backpack.
But I am having problem with my Arduino Code, I cannot open any file of the SD Card to either Read or Write the servo data.
I discarded that the problem comes from Proteus since I was able to Read and Write in this other simulation.
And here is the code that worked:
(It is basically the Read and Write example from the library, but extended to create multiple files).
#include <SPI.h>
#include <SD.h>
const int chipSelect = 4;
// Create the String that names each file with a unique name
String filename;
// Create multiple File Objects and put them in an array (Arduino Uno runs out of memory)
File myFile, myFile2, myFile3,myFile4, //Define files to open.
myFile5,myFile6,myFile7,myFile8,myFile9,
myFile10,myFile11,myFile12;
File myFiles[12] = {myFile, myFile2, myFile3,myFile4, //Create an array of files to open.
myFile10,myFile11,myFile12};
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    while (1);
  Serial.println("card initialized.");
  //***** READ AND WRITE PROGRAM ****************
  for( int i = 0; i < 12; i ++){
   filename = "";
   filename = "File" + String(i) + ".txt";
   myFiles[i] = SD.open(filename , FILE_WRITE);
   // if the file opened okay, write to it:
   if (myFiles[i]) {
     Serial.print("Writing to " + filename +"...");
     myFiles[i].println("testing 1,2,3...");
     // close the file:
     myFiles[i].close();
     Serial.println("done.");
   else {
     // if the file didn't open, print an error:
     Serial.println("error opening " + filename);
   // re-open the file for reading:
   myFiles[i] = SD.open(filename);
   if (myFiles[i]) {
     Serial.println(filename + ": ");
     // read from the file until there's nothing else in it:
     while (myFiles[i].available()) {
       Serial.write(myFiles[i].read());
     // close the file:
     myFiles[i].close();
   else {
  } //End for.
  // nothing happens after setup
And here are the results from the simulation:
(I was able to Read and Write in 12 files)
But when I try it in my project with the servos I cannot even open the SD files...
Since I am new I cannot upload my Arduino Code yet. But please take a look at the sections of my code that are supposed to open the SD file.
The code looks like this in my not working project:
First, let me show you the function I am using for Reading my CSV files:
(I cannot open the file, so anything below that line I have not tested)
/* ----------------------FUNCTION 2------------------------------*/
// PLAY AUTOMATIC SERVO CONTROL FROM SD FILE (just one row)
void playloopCode() {
  Serial.println ("Playing...");                       //SERIAL PRINT
  fileFlag=false;
  //****** READ SD FILE PROGRAM ************//
  // String to hold one line of text
  char servoData[8]; // it will hold:  VRX_angle,VRY_angle
  char* servo1; // it will hold VRX
  char* servo2; // it will hold VRY
  // Create File Name Char Array
  char filename[10];
  int i = menu-1;
  char buf [sizeof(uint8_t)*8+1];
  itoa (i,buf,10);
  strcpy (filename,"File");
  strcat (filename,buf);
  strcat (filename,".txt ");
  Serial.println(filename);                              //SERIAL PRINT
  // Test if there file exists
  if (!SD.exists(filename)){
    Serial.println("File DOES NOT Exist");               //SERIAL PRINT
    fileFlag=true;
    return;
  else{
    Serial.println("File Exists");                       //SERIAL PRINT
    fileFlag=false;
  // Open File with filename
  myFiles[i] = SD.open(filename);                       //-----------------------SD OPEN FILE (NOT WORKING) ---------------------------------//
  // If the file is available, read it
  if (myFiles[i]) {
      // Get one char from .txt
      char letter = myFiles[i].read();
      // Write one line to buffer
      while (letter!='\n'){
        strcat (servoData,letter);
      // ************ PARSE CSV PROGRAM ****************//
    servo1=strtok(servoData, ",");
    //Serial.println(servo1);
    servo2=strtok(NULL, "\n");
    //Serial.println(servo2);
    VRX_angle = atoi(servo1);
    VRY_angle = atoi(servo2);
    Serial.println(VRX_angle);
    Serial.println(VRY_angle);
    // ************** SERVO PROGRAM ***************************//
    servoAngleLeft = VRY_angle+(SW_flag)*VRX_angle;
    servoAngleRight = VRY_angle-(SW_flag)*VRX_angle;
    // MAX LEFT SERVO LIMIT
    if (servoAngleLeft>180) {
    servoAngleLeft =180;
    if (servoAngleLeft<0) {
    servoAngleLeft =0;
    // MAX RIGHT SERVO LIMIT
    if (servoAngleRight>180) {
    servoAngleRight =180;
    if (servoAngleRight<0) {
    servoAngleRight =0;
    myservoLeft.write(servoAngleLeft);
    myservoRight.write(servoAngleRight);
    delay(15);
    // close the file:
   myFile.close();
  else {                                                        //-----------------------ERROR OPENING SD FILE ---------------------------------//
   lcd.setCursor(0, 1);                                         //LCD PRINT
   lcd.print(F("Open File Error!"));
   Serial.print("error opening ");                              //SERIAL PRINT
   delay(100);                                                  //DELAY 0.1 SEC
}// END of playloopCode();
And here is the code for writting in the SD Card:
(same problem, I cannot open the file)
/* ----------------------FUNCTION 3------------------------------*/
// RECORD JOYSTICK IN SD CARD (one row at a time) - NOTE: SERVOS ALSO MOVE!
void recordCode() {
  Serial.println ("Recording...");                              //SERIAL PRINT
  //****** JOYSTICK PROGRAM ************//
  // JOYSTICK VALUES
  VRX_angle = map(analogRead(A0), 0, 1023, -60, 60);
  VRY_angle = map(analogRead(A1), 0, 1023, 0, 180);
  SW_value = digitalRead(SWPin);  // read Button state [0,1]
  if (!SW_value){
    SW_flag*=-1;
    delay(100);
    while (!digitalRead(SWPin));
  servoAngleLeft =0;
  servoAngleRight =0;
  delay(15);
  //****** WRITE IN SD FILE PROGRAM ************//
  char filename[10];
  int i = menu-1;
  itoa (i,buf,10);
  //Delete File before creating a new one
  if (SD.exists(filename)){
    SD.remove(filename);
    delay(100);
  //Creating a New File
  myFiles[i] = SD.open(filename , FILE_WRITE);          //-----------------------SD OPEN FILE (NOT WORKING) ---------------------------------//
  if (myFiles[i]) {
    Serial.println("Writing to file...");               //SERIAL PRINT
    // ******* WRITE JOYSTICK DATA (only one row)*******
    myFiles[i].print(VRX_angle);
    myFiles[i].print(",");
    myFiles[i].println(VRY_angle);
    // close the file:
    myFiles[i].close();
    Serial.println("done.");                            //SERIAL PRINT
}//END of recordCode();
I have no idea why it works in the Example and not in my Project. So I would appreciate any ideas and comments. All I have as a beginner is the Read and Write Example and the DataLogger Example. Also, I used this tutorial: https://dronebotworkshop.com/sd-card-arduino/
The Version of my Libraries are:
Wire -1.0
LiquidCrystal_I2C-master 1.1.4
SPI - 1.0
SD - 1.2.3
Servo - 1.1.5
And the storage is:
57% of program storage
72% of dynamic memory
Any help or comment is appreciated, thanks :slight_smile:
Okey... so I've been working a little bit more and I found out that if I write a "constant or fixed" name in SD.open(), the code works. I can write a .txt file in my SD card. (I still have to debug the reading part, but at least it opens the file)
So I think the problem comes from the way I am naming my files.
Here is the code:
(this is for writing in the SD card)
  char filename[10];
  int i = menu-1;
  itoa (i,buf,10);
    Serial.println("Deleting Existing File...");
  Serial.println("Opening File...");
  delay(1000); //only for testing
  //myFiles[i] = SD.open(filename , FILE_WRITE);  //  <---- it doesn't work here...
  myFiles[i] = SD.open("test.txt" , FILE_WRITE); //  <---- it works here !!!
Why is this happening? Can't I use a Char array to name my files?
"File" is 4 chars ".txt" is 4 chars. one char for terminating 0 and one char is left for the number. but I see you have File10.txt
Nevermind... the problem was a "space" I did not see here:
(now Read and Write works)
  char filename[10];
  int i = menu-1;
  itoa (i,buf,10);
  strcat (filename,".txt"); //<--------- I had a space at the end of .txt
Well, now I just have to debug the Playing Mode. This is the new one:
(It is only reading the first line of the .txt file, and it should read all of them)
  fileFlag=false;
  char servoData[8]; // it will hold:  VRX_angle,VRY_angle[NULL]
  char filename[10];
  int i = menu-1;
  itoa (i,buf,10);
  //if (!SD.exists("test.txt")){ // ----------------------------------------------------test---------------
    fileFlag=true;
    return;
  else{
    fileFlag=false;
  myFiles[i] = SD.open(filename);                       //-----------------------SD OPEN FILE (READING) ---------------------------------//
    //myFiles[i] = SD.open("test.txt");// ----------------------------------------------------test---------------
  bool newLine=false;
  if (myFiles[i]) {
  //char lineOne[80]; // Assumes that a line contains no more than 79 characters
  byte index = 0;
  while(myFiles[i].available() > 0)
     char nextChar = myFiles[i].read();
     if(nextChar != '\n')
        servoData[index++] = nextChar;
        servoData[index] = '\0'; // Keep array NULL terminated
         //Serial.print("servoData: ");
         //Serial.println(servoData);
     //Serial.println("I made it out of the loop!!!!!!!!!!!");
     //delay(1000);
    Serial.print("VRX: ");
    Serial.print("VRY: ");
    //Serial.print("LeftServo: ");
    //Serial.println(servoAngleLeft);
    //Serial.print("RightServo: ");
    //Serial.println(servoAngleRight);
    servoAngleLeft =0;
    servoAngleRight =0;
    delay(15);
    // close the file:
   myFiles[i].close();
   //Serial.println("test.txt"); // ------------------------ -------------------  test
you still write out of 10 chars reserved for filename
Hi, thank you for replying
Is having 10 chars reserved for filename wrong?
I wrote 10 because "File" has 4.
1 more for the file number (I won't have 2 digit numbers because the Arduino is running out of dynamic memory)
and ".txt" has 4 plus 1 more for the Null char
So the total for my char array is 10, right? Or am I confussing it with string (with small s) ?
on you sreenshot I see File11.txt
Yes, that was the code I used to verify that the problem did not come from Proteus. In that code I used the example ReadWrite from the SD library. That code uses String objects to name the files, but I don't like it because it uses a lot of Dynamic Memory.
See here:
That is why I changed it to char array.
See here:
