Hi everybody, I have written a code for my project. this code is working perfectly with delay(). But I want to replace it with millis(). I am a beginner in Arduino. i just learned all things online.
here I am posting my code, Can any one help me to replace the delay() in my code. I will we always thankful to you.
/........CODE............/
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4); // set the LCD address to 0x27 for a 16 chars and 2 line display
// A4=SDA , A5=SCL //
// motor M1 motor
int inM1 = 12;
// motor M2 motor
int inM2 = 10;
int inBZ = 11; // Buzzer //
float potPin1 = 0; // Speed //
float potPin2 = 1; // Cotton Length //
float potPin3 = 2; // Counter //
float potPin4 = 3; // Hold Time //
float inval1 = 0; float outval1 = 0; // speed //
float inval2 = 0; float outval2 = 0; // length //
float inval3 = 0; float outval3 = 1; // counter //
float inval4 = 0; float hld = 0; float hld1 = 0; // hold time //
float len = 0; float outval5 = 0;
float cnt = 1; // counter //
float spd = 1; float wicks = 0;
float cwc = 0;
float ov3 = 1;
Serial.begin(9600); // set all the motor control pins to outputs
pinMode(inM1, OUTPUT); pinMode(inM2, OUTPUT); pinMode(inBZ, OUTPUT);
lcd.init(); lcd.backlight();
lcd.setCursor(6, 0); lcd.print("WELCOME");
lcd.setCursor(4, 1); lcd.print("To Our Team");
lcd.setCursor(0, 2); lcd.print("<<EXTREME MACHINE>>");
lcd.setCursor(3, 3); lcd.print("please wait...");
delay (10000);
inval1 = analogRead(potPin1); inval2 = analogRead(potPin2); inval3 = analogRead(potPin3); inval4 = analogRead(potPin4);
lcd.setCursor(0, 0); lcd.print("<<EXTREME MACHINE>>");
lcd.setCursor(0, 1); lcd.print("Cnt");
lcd.setCursor(10, 1); lcd.print("Hld");
lcd.setCursor(18, 1); lcd.print("Sc");
lcd.setCursor(0, 2); lcd.print("Spd");
lcd.setCursor(10, 2); lcd.print("Len");
lcd.setCursor(18, 2); lcd.print("In");
lcd.setCursor(0, 3); lcd.print("Cwc");
lcd.setCursor(10, 3); lcd.print("Twc");
cwc = 1;
for (cnt = 1; cnt <= outval3; cnt += 1) {
outval3 = map(inval3, 0, 1023, 10, 551); // counter//
ov3 = outval3;
outval1 = map(inval1, 0, 1023, 50, 500); //Speed//
spd = map(outval1, 50, 500, 10, 0); // speed display //
outval2 = map(inval2, 0, 1023, 20, 110); // length//
outval5 = map(outval2, 20, 110, 20, 900); // Adjust display of length here //
len = map(outval5, 20, 900, 200, 586); // length display //
hld = map(inval4, 0, 1023, 0, 66); // hold time//
hld1 = hld * 10;
// turn on M1 & M2 motor FOR SAME TIME LENGTH //
digitalWrite(inM1, HIGH); delay(000);
digitalWrite(inM2, HIGH); delay(outval2); // time lenght of M1 amd M2 simultaniouslly //
digitalWrite(inM1, LOW); delay(000);
digitalWrite(inM2, LOW); delay(outval1); // OFF time gap between M1-M2 and M2 //
// turn on M2 motor alone //
digitalWrite(inM2, HIGH); delay(outval2 + 50); // RUN time of M2 alone //
digitalWrite(inM2, LOW); delay(outval1); // OFF time between M2 and M1-M2 //
if (digitalRead(inM1) > 0) ; {
wicks = wicks + 1;
lcd.setCursor(4, 1); lcd.print(ov3, 1);
lcd.setCursor(14, 1); lcd.print(hld1 / 10, 1);
lcd.setCursor(4, 2); lcd.print(spd, 1);
lcd.setCursor(14, 2); lcd.print(len / 100, 2);
lcd.setCursor(4, 3); lcd.print(cwc, 1);
lcd.setCursor(14, 3); lcd.print(wicks, 1);
Serial.print(outval1) ;
Serial.print('\n');
Serial.print(outval2) ;
Serial.print('\n');
Serial.print(outval2 + 30) ;
Serial.print('\n');
cwc = cwc + 1;
digitalWrite(inBZ, HIGH); delay(100);
digitalWrite(inBZ, LOW); delay(25);
digitalWrite(inBZ, HIGH); delay(200);
digitalWrite(inBZ, LOW); delay(50);
digitalWrite(inBZ, HIGH); delay(300);
digitalWrite(inBZ, LOW); delay(000);
delay(hld * 1000);
