Need help to set four PWM output pin frequencies to 25kHz
I currently can set four pwm pins to around 31kHz with the following code:
    TCCR1B = TCCR1B & B11111000 | B00000001; // Set PWM frequency for D9 & D10 :
    pinMode(pwmPin9, OUTPUT); // sets the pin as output
    pinMode(pwmPin10, OUTPUT); // sets the pin as output
    TCCR2B = TCCR2B & B11111000 | B00000001; // Set PWM for D3 & D11
    pinMode(pwmPin3, OUTPUT); // sets the pin as output
    pinMode(pwmPin11, OUTPUT); // sets the pin as output
I found this setup somewhere but I don't know how I can set these four pwm pins to around 25kHz instead. How is that possible?
frequencies you can get to are equal to the base frequency of the pin divided by a given divisor
Base frequencies:
  • The base frequency for pins 3, 9, 10, and 11 is 31250 Hz.
  • The base frequency for pins 5 and 6 is 62500 Hz.
Divisors:
  • The divisors available on pins 5, 6, 9 and 10 are: 1, 8, 64, 256, and 1024.
  • The divisors available on pins 3 and 11 are: 1, 8, 32, 64, 128, 256, and 1024.
So no you can't...
See this section for details and consequences on playing with frequencies
