Good day to all,
i am trying yo write code to display menu when a key from keypad. i am using 162 lcd display and 43 matrix keypad.
my requirements are
when '3' is pressed displaying the menu starts from point 1, and after that if '2' is pressed previous two menu points will get displayed and if '5' is pressed next two menu points will get displayed,
here is menu
- Set Point
- Dose timing
- Dose interval
- ph lower/Upper
- forced dose
- alarm-deviation
- alarm-dose/hr
8 .alarm on/off - calibration ph7
10.calibration ph4
and one thing for which i have absolutely no idea how to do is, if anywhere in the middle if '0' is pressed program must return to main loop.
i apologies if i havent use language properly of any other mistake.
thank you for help.
here is the code that i have written:
#include <Keypad.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd (5,4,3,2,1,0);
const byte ROWS = 4;
const byte COLS = 3;
char mainKeys [4][3] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
char menuKeys [4][3] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'','0','#'}
char level_1Keys [4][3] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'','0','#'}
char level_2Keys [4][3] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'','0','#'}
char level_3Keys [4][3] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'','0','#'}
char level_4Keys [4][3] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'','0','#'}
char leve_5Keys [4][3] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'','0','#'}
byte rowPins [4] = {12,11,10,9};
byte colPins [3] = {8,7,6};
Keypad mainpad (makeKeymap(mainKeys),rowPins,colPins,sizeof(rowPins),sizeof(colPins));
Keypad level_1pad (makeKeymap(level_1Keys),rowPins,colPins,sizeof(rowPins),sizeof(colPins));
Keypad level_2pad (makeKeymap(level_2Keys),rowPins,colPins,sizeof(rowPins),sizeof(colPins));
Keypad level_3pad (makeKeymap(level_3Keys),rowPins,colPins,sizeof(rowPins),sizeof(colPins));
Keypad level_4pad (makeKeymap(level_4Keys),rowPins,colPins,sizeof(rowPins),sizeof(colPins));
Keypad level_5pad (makeKeymap(level_5Keys),rowPins,colPins,sizeof(rowPins),sizeof(colPins));
lcd.begin (16,2);
lcd.print (" WELCOME ");
delay (3000);
lcd.clear ();
char key = mainpad.getKey ();
if ( key!= NO_KEY)
if (key =='3')
lcd.clear ();
menu ();
else {
lcd.setCursor (0,0);
lcd.print ("Current pH:7.0");
char menu ()
lcd.print ("1. Set Ppint");
delay (30);
lcd.setCursor (0,1);
lcd.print ("2. Dose Timing");
char key_1 = level_1.getKey ();
if (key_1!=NO_KEY)
if (key_1 == '2')
level_5 ();
else {
switch (key_1){
case 5:{
level_2 ();}
break ();
case 0:{
done ();}
default:{}
else {
/do nothing/
char level_2 ()
lcd.print ("3. Dose Interval");
delay (30);
lcd.print ("4. pH Lower/Upper");
char key_2 = level_2.getKey ();
if (key_2!=NO_KEY)
if (key_2 == '2')
menu ();
else {
switch (key_2){
case 5:{
level_3 ();}
break ();
case 0:{
done ();}
default:{}
else {
/do nothing/
char level_3 ()
lcd.print ("5. Forced Dose");
delay (30);
lcd.print ("6. Alarm-Deviation");
char key_3 = level_3.getKey ();
if (key_3!=NO_KEY)
if (key_3 == '2')
level_2 ();
else {
switch (key_3){
case 5:{
level_4 ();}
break ();
case 0:{
done ();}
default:{}
else {
/do nothing/
char level_4 ()
lcd.print ("7.Alarm- Dose/hr");
delay (30);
lcd.print ("8. Alarm On/Off");
char key_4 = level_4.getKey ();
if (key_4!=NO_KEY)
if (key_4 == '2')
level_3 ();
else {
switch (key_4){
case 5:{
level_5 ();}
break ();
case 0:{
done ();}
default:{}
else {
/do nothing/
char level_5 ()
lcd.print ("9.Calb pH7");
delay (30);
lcd.print ("10. Calb ph4");
char key_5 = level_5.getKey ();
if (key_5!=NO_KEY)
if (key_5 == '2')
level_4 ();
else {
switch (key_5){
case 5:{
menu ();}
break ();
case 0:{
done ();}
default:{}
else {
/do nothing/
void done ()
