i managed to get a Nano and ENC28J60 module working yesterday but it won't work today !
yesterday it worked as a web server;
// copy direct from backSoon-ino #
// Present a "Will be back soon web page", as stand-in webserver.
// 2011-01-30 <jc@wippler.nl> http://opensource.org/licenses/mit-license.php
#include <EtherCard.h>
#define STATIC 0 // set to 1 to disable DHCP (adjust myip/gwip values below)
#if STATIC
// ethernet interface ip address
static byte myip[] = { 192,168,6,7 };
// NOT showing in DCHP Active IP table ?
// just pick one NOT currently in use
// gateway ip address
static byte gwip[] = { 192,168,6,3 };
#endif
// ethernet mac address - must be unique on your network
static byte mymac[] = { 0x02,0xDD,0xDD,0x00,0x00,0x01 };
// DOESN'T SHOW - HOW TO KNOW ?!
byte Ethernet::buffer[500]; // tcp/ip send and receive buffer
char page[] PROGMEM =
"HTTP/1.0 503 Service Unavailable\r\n"
"Content-Type: text/html\r\n"
"Retry-After: 600\r\n"
"\r\n"
"<html>"
"<head><title>"
"Service Temporarily Unavailable"
"</title></head>"
"<body>"
"<h3>This service is currently unavailable</h3>"
"<p><em>"
"The main server is currently off-line.
"Please try again later."
"</em></p>"
"</body>"
"</html>"
void setup(){
Serial.println("\n[backSoon]");
if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
Serial.println( "Failed to access Ethernet controller");
#if STATIC
ether.staticSetup(myip, gwip);
#else
if (!ether.dhcpSetup())
Serial.println("DHCP failed");
#endif
ether.printIp("IP: ", ether.myip);
ether.printIp("GW: ", ether.gwip);
ether.printIp("DNS: ", ether.dnsip);
void loop(){
// wait for an incoming TCP packet, but ignore its contents
if (ether.packetLoop(ether.packetReceive())) {
memcpy_P(ether.tcpOffset(), page, sizeof page);
ether.httpServerReply(sizeof page - 1);
// Serial.println("WAITING!...");
as well as a web client;
// Demo using DHCP and DNS to perform a web client request.
// 2011-06-08 <jc@wippler.nl> http://opensource.org/licenses/mit-license.php
// ethernet interface mac address, must be unique on the LAN
byte Ethernet::buffer[700];
static uint32_t timer;
char website[] PROGMEM = "www.google.com";
// called when the client request is complete
static void my_callback (byte status, word off, word len) {
Serial.println(">>>");
Ethernet::buffer[off+300] = 0;
Serial.print((const char*) Ethernet::buffer + off);
Serial.println("...");
void setup () {
Serial.println("\n[webClient]");
if (!ether.dnsLookup(website))
Serial.println("DNS failed");
ether.printIp("SRV: ", ether.hisip);
void loop () {
ether.packetLoop(ether.packetReceive());
if (millis() > timer) {
timer = millis() + 5000;
Serial.print("<<< REQ ");
ether.browseUrl(PSTR("/foo/"), "bar", website, my_callback);
but now it won't even get past setup()
- can anybody help with where the problem could be ?
even more fundamental - if the Arduino+Ethernet is not showing in the Router's Client Table - what would the error be ?
