Need help trying to use motor driver
Hi there!
I needed to run a few heavy (12V) motors from my arduino, which couldn't be handled by my L293D motor driver, so I bought a new one here - Dual DC Motor Driver 20A Dual DC Motor Driver 20A [RKI-1341] - ₹750.00 : Robokits India, Easy to use, Versatile Robotics & DIY kits
I got the driver delivered today, okay so it has 5 inputs for each pin, 5V, GND (both from Arduino ) and then a PWM, BRAKE and DIR. Documentation for the board is available on the link provided.
When I hooked it up to my Arduino, I provided the 5V and GND inputs, and a red LED lights up on the board. Next I attach a 8V battery pack, and a motor to the external power input and motor output respectively. Finally I attached the PWM and DIR pin to pins 8 and 9 on the Arduino (UNO). There after I uploaded this test code -
P.S- E1 is the PWM pin and LeftMotorForward is the DIR pin.
int LeftMotorForward = 8;
int E1 = 9;
pinMode(LeftMotorForward, OUTPUT);
pinMode(E1, OUTPUT);
digitalWrite(E1, HIGH);
digitalWrite(LeftMotorForward, HIGH);
digitalWrite(LeftMotorForward, LOW);
The code got uploaded but nothing happened. My motor didn't move. What mistake I am doing? I can't understand the documentation very much.
And what should I do to use this driver to its fullest?
Thanks!
If you are using E1 (pin 9) in PWM mode you will have to use analogWrite instead of digitalWrite and also give it a number (0-255) to tell it what time ratio to run at. Take a look at "analogWrite()" in the Arduino reference.
Also your code sets "LeftMotorForward" HIGH for 1 second then sets it LOW and immediately the loop goes back to the start and sets it HIGH again so it is LOW for only a very very short time. Is this what you wanted?
