Hello,
I am using CANBed M4 board to read OBDII messages from a car. I am using following library with this board and I am able to read messages on the CAN bus.
Unfortunately the messages seems to not follow OBDII format as I can not seem to decode any of them in accordance with OBDII message structure.
Here is what I am seeing in CSV format:
ID,LENGTH,DATA
368,3,C0A1B
372,8,654499BB08000
644,8,3EC13E721E4AF6
374,8,A1D6103ADE600
451,8,000000FFC3
375,8,FE00011000
645,8,3E7D3E454D0AFC1
646,5,EEE554A4
682,8,008088000B4
683,8,0008A007C1F
688,8,0FFF8C1B0CE0
2,5,B3FF0787
734,8,0009400E93
768,1,0
352,7,3983B5110EEE0
384,8,30573B539812300
386,8,FF0001400EF
505,8,6820305700560
368,3,C4A25
372,8,654499BB18000
581,8,FFE0018010FFE0
374,8,A236B3AB0610
658,8,7F186281800140
1004,2,2FA0
689,6,0040000
734,8,0009400E93
1477,8,400B0D10C00
533,7,FFF4FF30FFFF0
534,2,400
352,7,3963B41080EF60
384,8,30703B439612310
386,8,FF0001310EF
505,8,6820307000560
368,3,C8A22
372,8,654498BB28000
645,8,3E833E2E4D0B0B1
374,8,A1B6123A7A620
451,8,000002FFC5
644,8,3EC63E7D1E9B01C
683,8,0008A007B63
734,8,0009400E93
768,1,0
352,7,3963B5100EFE0
384,8,30573B539611F20
386,8,FF0001320EE
505,8,6820305700560
569,8,1EE0A0204111FB80
853,8,1E501EF93044600
368,3,CCA28
For example, if I should see some basic PID's for Engine RPM (0C) and Vehicle Speed (0D).
Any input is appreciated as I am pretty new to this.
Following is the sample code I am using to generate this CSV file:
CAN 2.0 send example for CANbed M4
begin(uint8_t idmodeset, uint32_t speedset, enum mcan_can_mode canmode)
@idmodeset:
#define MCP_STDEXT 0 // Standard and Extended
#define MCP_STD 1 // Standard IDs ONLY
#define MCP_EXT 2 // Extended IDs ONLY
#define MCP_ANY 3 // Disables Masks and Filters
@speedset:
#define CAN_4K096BPS 4096
#define CAN_5KBPS 5000
#define CAN_10KBPS 10000
#define CAN_20KBPS 20000
#define CAN_31K25BPS 31250
#define CAN_33K3BPS 33300
#define CAN_40KBPS 40000
#define CAN_50KBPS 50000
#define CAN_80KBPS 80000
#define CAN_100KBPS 100000
#define CAN_125KBPS 125000
#define CAN_200KBPS 200000
#define CAN_250KBPS 250000
#define CAN_500KBPS 500000
#define CAN_1000KBPS 1000000
@canmode:
MCAN_MODE_CAN ISO 11898-1 CAN 2.0 mode
MCAN_MODE_EXT_LEN_CONST_RATE Long CAN FD frame.
* - TX and RX payloads up to 64 bytes.
* - Slow transmitter: TX frames are sent at constant bit rate.
* - Fast receiver: both constant-rate (slow) and dual-rate (fast)
* RX frames are supported and received.
MCAN_MODE_EXT_LEN_DUAL_RATE Long and fast CAN FD frame.
* - Fast transmitter: control, data and CRC fields are transmitted at a
* higher bit rate.
* - Fast receiver.
#include <same51_can.h>
SAME51_CAN can;
while(!Serial);
uint8_t ret;
ret = can.begin(MCP_ANY, CAN_1000KBPS, MCAN_MODE_EXT_LEN_DUAL_RATE);
if (ret == CAN_OK)
// Print header
Serial.print("ID,");
Serial.print("LENGTH,");
Serial.print("DATA");
Serial.print("\n");
} else
Serial.println("Error Initializing CAN...");
while(1);
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
uint8_t ret;
uint32_t id;
uint8_t len;
uint8_t buf[8];
uint8_t i;
ret = can.readMsgBuf(&id, &len, buf);
if (ret == CAN_OK) {
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on
// check msg for RPM
Serial.print(id, HEX);
Serial.print(",");
Serial.print(len, HEX);
Serial.print(",");
for (i = 0; i < len; i++) {
Serial.print(buf[i], HEX);
Serial.print("\n");
else {
digitalWrite(LED_BUILTIN, LOW); // turn the LED off
//Serial.print("No message");
// END FILE
Thank you.
