I am trying to use the Random Hat example posted on the site. Here is the code as provided by Paul Badger:
/* RandomHat
Paul Badger 2007
choose one from a hat of n choices each time through loop
Choose each number exactly once before reseting and choosing again
#define randomHatStartNum 1
#define randomHatEndNum 4
#define NumInHat abs(randomHatEndNum - randomHatStartNum) + 1
int i, x;
Serial.println("start ");
{ // randomHat test
for (i=1; i<=NumInHat; i++){
x = randomHat();
Serial.print(x);
Serial.print(" “);
delay(100);
Serial.println(” ");
int randomHat(){
static int totalNumInHat = abs(randomHatEndNum - randomHatStartNum) + 1;
static int currentNumInHat = 0;
static int randArray[abs(randomHatEndNum - randomHatStartNum) + 1];
int i; //as long as they can be changed without harming other code
int thePick; //this is the return variable with the random number from the pool
int theIndex;
if (currentNumInHat == 0){ // hat is emply - all have been choosen - fill up array again
for (i = 0 ; i<=(totalNumInHat - 1); i++){ // Put 1 TO numberInHat in array - starting at address 0.
if (randomHatStartNum < randomHatEndNum){
randArray *= randomHatStartNum + i; } *
- else if (randomHatStartNum > randomHatEndNum){ // defensive programming in case startNum is greater than endNum*
_ randArray = randomHatEndNum + i; }_
* else{*
* return randomHatStartNum; } // startNum and endNum must be same number - return one - and bail out*
* currentNumInHat = abs(randomHatEndNum - randomHatStartNum) + 1; // reset current Number in Hat*
* //if something should happen when the hat is empty do it here*
* theIndex = random(currentNumInHat); //choose a random index *
* thePick = randArray[theIndex];*
* for (i = theIndex; i<= (currentNumInHat - 1); i++){*
_ randArray = randArray[i + 1]; // bump all the higher array contents down one, erasing the last number chosen
currentNumInHat–; // decrement counter*
* return thePick;
OK, the code runs as posted, however, it continues to run forever since the ‘call’ to the function is in the void loop () section. Normally this is good, however I only want to run the call one time and then I will store the results for later use. I tried to simply move it up into the void setup () section, however the compiler just gave me errors.
So now is there some way to leave the ‘call’ in the void loop () section and run it only once? I believe someone has faced this before and has figured out out how to accomplish this task.
Thanks in advance for your help and to Paul for posting the example code._
