need help understanding pin out in led matrix code
I don't understand how to connect my arduino to the LED matrix. The only line in the code that gives some instruction how is
pin[xx] on led matrix connected to nn on Arduino
you can find the rest of the code here
http://playground.arduino.cc/Main/DirectDriveLEDMatrix
thanks
// pin[xx] on led matrix connected to nn on Arduino (-1 is dummy to make array start at pos 1) int pins[17]= {-1, 5, 4, 3, 2, 14, 15, 16, 17, 13, 12, 11, 10, 9, 8, 7, 6};
so as called out for the code below: pins[0] = -1 pins[1] = 5 pins[2] = 4 etc pins[14] = 8 pins[15] = 7 pins [16] = 6
No doubt some adjusting will be needed if you don't have the very same matrix.
// col[xx] of leds = pin yy on led matrix int cols[8] = {pins[13], pins[3], pins[4], pins[10], pins[06], pins[11], pins[15], pins[16]};
// row[xx] of leds = pin yy on led matrix int rows[8] = {pins[9], pins[14], pins[8], pins[12], pins[1], pins[7], pins[2], pins[5]};
Thanks for replying
this adds some clarification, but I think that there is no pin -1 connected to anything. Also is this the correct pinout
arduino/matrix 1 /5 2 /4 3 /3 4 /2 5/14 6/15 7/16
etc
And after this all I have to do is change it based on the rows and columns of my display?
thanks for the help
There is no pin -1 because the pins[0] is not called out: // col[xx] of leds = pin yy on led matrix int cols[8] = {pins[13], pins[3], pins[4], pins[10], pins[06], pins[11], pins[15], pins[16]};
YourArduino/Matrix mapping is correct.
