Hello need help to understand where my rpm-s are disappearing
im not programmer or electronic so be gentle :-* Setup:
arduino UNO (powered over USB)
arduino motor shield rev3 (powered from 9V alkaline battery)
DC micromotor
Operating voltage: 1.5-6.5V DC
Rated Voltage: 6V DC
No load speed: 12000±15%rpm
No load current: 280mA
if I connect motor directly to battery it rotates clearly faster when I connect it through motor shield.
in code the speed is set to 255
does the motor shield drawing so much power that it is visible with naked eye? I dont have tester to evaluate exact motor input values.
So how to control motor input voltage if i use small motor but bigger battery pack? or if i want to use two motors with different voltage need?
how to control motor input voltage if I want to use two motors with different voltage need?
Motors don't have a "voltage need".
Your project needs mechanical power, so you should pick a motor that provides the speed and torque necessary for the project. The speed is controlled by the voltage and the torque is controlled by the current. If you are building a robot, there is some useful background here.
jremington:
Motors don't have a "voltage need". ..... . The speed is controlled by the voltage ...
thanks for correcting me but dont take offense if say that you are probably engineer -as you answer is totally correct and in this case useless.
and if you think who I am... you are correct too
So behalf "voltage need" read " input voltage" or if you want "speed and torque" is this more correct?
Situation- if I have 12V power supply and i want to use one motor what needs 12V to work on needed "speed and torque" and same time other motor needs just 3V to work on its needed "speed and torque"
if i connect this 3V motor to 12V power supply it will probably rotate too quickly
So what are my options to get proper voltage to these motors?
thanks you answered my question I was just theorizing and wanted confirmation that with just arduino + motor shield I cant control motors with different voltage need so its better to use two separated motor controllers.
jremington:
PWM does not regulate the voltage, it just changes the average current.
nswer, post the characteristics of the motors and the torque and speed requirements of your project.
Depends on the mode, in synchronous rectification mode PWM directly controls the average voltage,
which is why its great for motion control loops (if not the most efficient).
For slow/fast/mixed decay modes the relationship between PWM duty cycle and output is non-linear and
quite complicated in practice.
