Need help understanding some interrupt code
I'm trying to get my head around how the sparkfun frequency counter code works and it's doing my head in.
Reading through it has me understanding that it's doing a lot of counting with timer 1 yet somehow it's using pin 5 to trigger everything and for the life of me I cannot see where pin 5 which is associated with timer 0 actually fits into the code.
The following snippet in the code would indicate that this is where pin 5 is being worked into the mix
// External clock source on D5, trigger on rising edge:
TCCR1B = (1<<CS12) | (1<<CS11) | (1<<CS10);
But from what I can gather TCCR1B, CS12, CS11 and CS10 are all related to timer 1 and would have no relationship to pin5
Ultimately what I want to do is move the input pin from pin 5 to one of my free pins (0 to 4 and 11 to 13) but even if it's not actually possible I still cannot see how it's working from pin 5 to see how or why it wouldn't work off another pin.
 Frequency Counter Arduino Sketch
 by: Jim Lindblom
 SparkFun Electronics
 License: Beerware
 This isn't the most accurate frequency counter, but it's simple to
 program and understand, and it works in a pinch. I've tested it to
 be accurate to at least 96% (usually around 99.5%). It should be
 able to measure frequencies up to about 6.5MHz(8MHz optimally)
 The circuit: Powered at 5V (5V LCD), Arduino running at 16MHz
 D2 - RS (LCD)
 D3 - R/W (LCD)
 D4 - E (LCD)
 D5 - Frequency input
 D6 - DB4 (LCD)
 D7 - DB5 (LCD)
 D8 - DB6 (LCD)
 D9 - DB7 (LCD)
 D10 - Gate of NPN transistor (Collector tied to 5V, emitter tied to LCD backlight pin)
For the LiquidCrystal library, much thanks to:
   David A. Mellis
   Limor Fried (http://www.ladyada.net)
   Tom Igoe
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(2, 3, 4, 6, 7, 8, 9);
int brightness;
unsigned int tovf1 = 0;
unsigned long frequency = 0;
unsigned long temp = 0;
// Timer 1 is our counter
// 16-bit counter overflows after 65536 counts
// tovfl will keep track of how many times we overflow
ISR(TIMER1_OVF_vect)
  tovf1++;
  pinMode(5, INPUT);  // This is the frequency input
  pinMode(10, OUTPUT);  // Backlight control pin
  digitalWrite(10, HIGH);  // Turn backlight on
  // Timer 1 will be setup as a counter
  // Maximum frequency is Fclk_io/2
  // (recommended to be < Fclk_io/2.5)
  // Fclk_io is 16MHz
  TCCR1A = 0;
  // Enable overflow interrupt
  // Will jump into ISR(TIMER1_OVF_vect) when overflowed:
  TIMSK1 = (1<<TOIE1);
  // set up the LCD's number of rows and columns:
  lcd.begin(16, 2);
  // Print a splash screen to the LCD.
  lcd.print("FrequencyCounter");
  lcd.setCursor(0, 1);
  lcd.print("      v1.0      ");
  delay(2000);
  // Delay a second. While we're delaying Counter 1 is still
  // reading the input on D5, and also keeping track of how
  // many times it's overflowed
  lcd.clear();
  frequency = (TCNT1H<<8)|TCNT1L;
  // Correct weird counter bug
  // A small range of frequencies (~30k-50k) are getting
  // 42949 appended to the front of them
  // Will look into this but this works for now
  if (frequency > 40000000)
    frequency -= 4294900000;
  // 65536 (2^16) is maximum of counter
  // We'll multiply that by how many times we overflowed
  temp = 65536*(unsigned long)tovf1;
  // Add the overflow value to frequency
  frequency += temp;
  // Print the proper amount of spaces to make it look pretty
  lcd.setCursor(0,1);
  if (frequency < 100)
    lcd.print("      ");
  else if (frequency < 10000)
    lcd.print("     ");
  else if (frequency < 1000000)
    lcd.print("    ");
    lcd.print("   ");
  lcd.print(frequency);
  lcd.print(" Hz");
  // Reset all counter variables and start over
  TCNT1H = 0;
  TCNT1L = 0;
  tovf1 = 0;
I'm presently reading the datasheet for the ATMega328 and can see that the snippet I referred to in the original post is setting timer 1 to respond to "External clock source on T1 pin. Clock on rising edge."
Ok. So I now get that, but still cannot see where "T1" is defined :~
I believe you are looking for PD6.
http://www.atmel.com/dyn/resources/prod_documents/doc2549.pdf page 2.
It isn't defined because it isn't configurable. The T1 pin is pin PD5. It cannot be changed as it is an internally hardwired configuration, Just as RXD and TXD are pins PD0 and PD1.
jraskell:
And external interrupts can be attached to pins 2 and 3...
Specifies a function to call when an external interrupt occurs. Replaces any previous function that was attached to the interrupt. Most Arduino boards have two external interrupts: numbers 0 (on digital pin 2) and 1 (on digital pin 3)...
I get it now. Thanks for that.
I'll resolder the pins i'm using on my LCD shield to free up pin 5.
jraskell:
I just had another look at the datasheet and T1 is pin PD6. PD5 is XCK.
bubulindo:
jraskell:
Wrong datasheet. Try this one. ATMega328
LOL
Where the hell did I got the idea that the OP was using a 2560??? :S LOLOL Sorry.
