Need help understanding the codes of a program
hi
i'm working on a little project that consists of an arduino based gps for may golf cart.
i made the project and it works fine, the only thing thats wrong is the size of the oled lcd.
what want to know is if i want to use , lets say a 3.5 inch tft mcfriend lcd, do i have to change every thing that is related to the u8g library? and add the tft library instead, not sure where ié,m going here
i've added the code so you can see
p.s. i'm not very good in coding thanks`
`#include "U8glib.h"
U8GLIB_SSD1351_128X128_332 u8g(13, 11, 8, 9, 7); // Arduino UNO: SW SPI Com: SCK = 13, MOSI = 11, CS = 8, DC = 9, RESET = 7
#define u8g_logo_sat_width 20
#define u8g_logo_sat_height 20
//satellite logo
const unsigned char u8g_logo_sat[] = {
  0x00, 0x01, 0x00, 0x80, 0x07, 0x00, 0xc0, 0x06, 0x00, 0x60, 0x30, 0x00,
  0x60, 0x78, 0x00, 0xc0, 0xfc, 0x00, 0x00, 0xfe, 0x01, 0x00, 0xff, 0x01,
  0x80, 0xff, 0x00, 0xc0, 0x7f, 0x06, 0xc0, 0x3f, 0x06, 0x80, 0x1f, 0x0c,
  0x80, 0x4f, 0x06, 0x19, 0xc6, 0x03, 0x1b, 0x80, 0x01, 0x73, 0x00, 0x00,
  0x66, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x3c, 0x00, 0x00, 0x70, 0x00, 0x00
// The serial connection to the GPS device
#include <SoftwareSerial.h>
static const int RXPin = 10, TXPin = 15;
static const uint32_t GPSBaud = 9600;
SoftwareSerial ss(RXPin, TXPin);
//GPS Library
#include <TinyGPS++.h>
TinyGPSPlus gps;
//Program variables
double Lat;
double Long;
//int day, month, year;
//int hour, minute, second;
int num_sat, gps_speed;
String heading;
const int ledCount = 10;    // the number of LEDs in the bar graph
int ledPins[] = {
  2, 3, 4, 5, 6, 14, A5, A4, A3, A2
};   // an array of pin numbers to which LEDs are attached
  ss.begin(GPSBaud);
  // assign default color value
  if ( u8g.getMode() == U8G_MODE_R3G3B2 ) {
    u8g.setColorIndex(255);     // white
  //Define ledpins as OUTPUT's
  for (int thisLed = 0; thisLed < ledCount; thisLed++) {
    pinMode(ledPins[thisLed], OUTPUT);
  Get_GPS(); //Get GPS data
  Led_Bar();//Adjust the LED bar
  //Display info in the OLED
  u8g.firstPage();
  do {
    print_speed();
  } while ( u8g.nextPage() );
void print_speed() {
  u8g.setFont(u8g_font_helvR24r);
  u8g.setPrintPos(2, 70);
  u8g.print(gps_speed , DEC);
  u8g.setPrintPos(60, 70);
  u8g.print("km/h");
  u8g.setFont(u8g_font_unifont);
  u8g.setPrintPos(85, 15);
  u8g.print( num_sat, 5);
  u8g.setPrintPos(15, 100);
  u8g.print("Lat:");
  u8g.setPrintPos(50, 100);
  u8g.print( Lat, 6);
  u8g.setPrintPos(10, 120);
  u8g.print("Long:");
  u8g.setPrintPos(50, 120);
  u8g.print( Long, 6);
  u8g.setPrintPos(0, 15);
  u8g.print( heading);
  u8g.drawXBM(108, 0, u8g_logo_sat_width, u8g_logo_sat_height, u8g_logo_sat);
// This custom version of delay() ensures that the gps object
// is being "fed".
static void smartDelay(unsigned long ms)
  unsigned long start = millis();
  do
    while (ss.available())
      gps.encode(ss.read());
  } while (millis() - start < ms);
void Get_GPS()
  num_sat = gps.satellites.value();
  if (gps.location.isValid() == 1) {
    Lat = gps.location.lat();
    Long = gps.location.lng();
    gps_speed = gps.speed.kmph();
    heading = gps.cardinal(gps.course.value());
    if (gps.date.isValid())
      day = gps.date.day();
      month = gps.date.month();
      year = gps.date.year();
    if (gps.time.isValid())
      hour = gps.time.hour();
      minute = gps.time.minute();
      second = gps.time.second();
  smartDelay(1000);
  if (millis() > 5000 && gps.charsProcessed() < 10)
    // Serial.println(F("No GPS detected: check wiring."));
void Led_Bar()
  int ledLevel = map(gps_speed, 0, 180, 0, ledCount);
    // if the array element's index is less than ledLevel,
    // turn the pin for this element on:
    if (thisLed < ledLevel) {
      digitalWrite(ledPins[thisLed], HIGH);
    } else { // turn off all pins higher than the ledLevel:
      digitalWrite(ledPins[thisLed], LOW);
Welcome to the Forum! You will get faster and better help if you post the code in code tags as requested by the forum guidelines.
Read the forum guidelines to see how to properly post code and some good information on making a good post. Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting.
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
If this will work as a drop in replacement depends on the hardware-interface the function calls of the libraries and maybe on the resolution of the two displays.
post links of the datasheets of your OLED display and the 3.5 inch tft mcfriend lcd
best regards Stefan
hi
i've been loooking for datasheets for these lcd i have and only found this for the oled
[SSD1306 128x64 Mono 0.96 Inch I2C OLED Display - Datasheet Hub]Preformatted text(SSD1306 128x64 Mono 0.96 Inch I2C OLED Display - Datasheet Hub)
as for the mcufriend display i cant find anything
https://electropeak.com/learn/absolute-beginners-guide-to-tft-lcd-displays-by-arduino/
