need help understanding
Hi can some one help me under this code? From void setup to Void loop. can someone briefly explain to me that portion. I'm new to arduino. Especially the break and case part and serial available()>0
#include <AFMotor.h>
//creates two objects to control the terminal 3 and 4 of motor shield
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
char command;
Serial.begin(9600); //Set the baud rate to your Bluetooth module.
void loop(){
if(Serial.available() > 0){
command = Serial.read();
Stop(); //initialize with motors stoped
//Change pin mode only if new command is different from previous.
//Serial.println(command);
switch(command){
case 'F':
forward();
case 'B':
back();
case 'L':
left();
case 'R':
right();
void forward()
motor1.setSpeed(255); //Define maximum velocity
motor1.run(FORWARD); //rotate the motor clockwise
motor2.setSpeed(255); //Define maximum velocity
motor2.run(FORWARD); //rotate the motor clockwise
void back()
motor1.run(BACKWARD); //rotate the motor counterclockwise
motor2.run(BACKWARD); //rotate the motor counterclockwise
void left()
motor2.setSpeed(0);
motor2.run(RELEASE); //turn motor2 off
void right()
motor1.setSpeed(0);
motor1.run(RELEASE); //turn motor1 off
void Stop()
motor1.setSpeed(0);
motor2.run(RELEASE); //turn motor1 off
motor2.setSpeed(0);
The Serial.available line is just testing that there is some serial data that has been received and is ready to be read. It is important to check that before you try to read any data from Serial.
The switch / case statement is explained in the reference.
