Need help urgently!!
Can anybody explain this code for me!!!
double result = 0;
float BATT1[5];
float BATTERY[21]; // J from 1 to 20
for(int J=1;J<=20;J++)
for(int k=0;k<10;k++)
BATT1[k] = getAnalog(J);
result += BATT1[k];
result = result / 10;
BATTERY[J] = result;
result = 0;
Looks to me that for each of 20 batteries it takes 10 readings, averages them, and saves that as the voltage for that battery.
but i'd change... float BATT1[5]; to float BATT1[10];
Looks to me as though there is a semi-colon missing
Yep, but float BATT1[5] is only 5 long so it over writes something else. BATT1 is not required.
Mark
Thanks for the reply zimboZA! But I don't really understand how is it done.
Does it do the inner loop first and if the condition is not true, i.e k=11, it will continue to divide by 10?
Stick a Serial.print() statement in there and learn for yourself.
adding comments into the code ALWAYS helps
  double result = 0;
  float BATT1[10];
  float BATTERY[21];
  // loop Battery J from 1 to 20
    // take 10 readings from Battery J and store sum in "result"
      result += BATT1[k]; // short way of doing result=result+BATT1[k]
    // store average of "result" back into Battery J location
    // reset "result" for next battery
    result = 0;
abrookfield:
  double result = 0;
float BATT1[10];
 float BATTERY[21];
   // take 10 readings from Battery J and store sum in “result”
// store average of “result” back into Battery J location
   // reset “result” for next battery
   result = 0;
Thanks alot!!
radons:
That’s Jimbo :slight_smile: … but you’re very welcome
