Need Help Using a V2 Module To Control A Servo
Hello everyone, I’m very new to Arduino (just got the board last Tuesday). I’m trying to use a V2 Voice module to control a servo and move that servo to different positions. So far just building up to this moment I made a simple code that let’s me control a servo to 3 positions using 3 input switches. I also learned how to program the V2 module and control some leds. Now I want to control that servo with the outputs from the V2 module. If anyone can take a look at my code I’d greatly appreciate it. I’ve been stuck for a few hours.
Problem Code below: (I’ll attach my two codes separately that I’m trying to merge together)
int button7= 9;
int button6= 10;
int button5= 11;
int redPin = 9;
int greenPin = 10;
int bluePin = 11; byte
com = 0; //reply from voice recognition
#include <Servo.h>
Servo myservo;
int pos=0;
void setup() { Serial.begin(9600);
pinMode(redPin, INPUT);
pinMode(greenPin, INPUT);
pinMode(bluePin, INPUT);
myservo.attach(5);
delay(2000);
Serial.write(0xAA);
Serial.write(0x37);
Serial.write(0xAA);
Serial.write(0x21);
while(Serial.available())
com = Serial.read();
switch(com)
case 0x11:
digitalWrite(redPin, HIGH);
button7=digitalRead(redPin);
button6=digitalRead(greenPin);
button5=digitalRead(bluePin);
if(button7==1 && button6==1 && button5==1)
myservo.write(0);
if(button7==1 && button6==0 && button5==1)
myservo.write(90);
if(button7==0 && button6==1 && button5==1)
myservo.write(145);
if(button7==1 && button6==1 && button5==0)
myservo.write(180);
case 0x12:
digitalWrite(greenPin, HIGH);
myservo.write(0);
myservo.write(90);
myservo.write(145);
myservo.write(180);
case 0x13:
digitalWrite(bluePin, HIGH);
myservo.write(0);
myservo.write(90);
myservo.write(145);
myservo.write(180);
case 0x14:
myservo.write(0);
myservo.write(90);
myservo.write(145);
myservo.write(180);
myservo.write(0);
myservo.write(90);
myservo.write(145);
myservo.write(180);
myservo.write(0);
myservo.write(90);
myservo.write(145);
myservo.write(180);
case 0x15:
digitalWrite(redPin, LOW);
myservo.write(0);
myservo.write(90);
myservo.write(145);
myservo.write(180);
digitalWrite(greenPin, LOW);
myservo.write(0);
myservo.write(90);
myservo.write(145);
myservo.write(180);
digitalWrite(bluePin, LOW);
myservo.write(0);
myservo.write(90);
myservo.write(145);
myservo.write(180);
Sorry here’s my two codes that work, that I’m trying to merge together.
Working Codes.doc (30 KB)
Why did you start a new thread?
PaulS: Why did you start a new thread?
In fact.... closing here...
