Need Help using Arduino with EasyVR
I am using an Arduino Uno with an EasyVR Sheild. I am trying to turn an LED on when I say ANNA to activate it, then say, GREEN_LED. This LED is fading on and off. Please help me if possible. The code is bellow.
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#include "SoftwareSerial.h"
SoftwareSerial port(12,13);
#else // Arduino 0022 - use modified NewSoftSerial
#include "WProgram.h"
#include "NewSoftSerial.h"
NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
//Groups and Commands
enum Groups
GROUP_0 = 0,
GROUP_1 = 1,
enum Group0
G0_ANNA = 0,
enum Group1
G1_GREEN_LED = 0,
EasyVRBridge bridge;
int8_t group, idx;
int led = 9; // the pin that the LED is attached to
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
int ledloop
// declare pin 9 to be an output:
pinMode(led, OUTPUT);
// bridge mode?
if (bridge.check())
cli();
bridge.loop(0, 1, 12, 13);
// run normally
port.begin(9600);
if (!easyvr.detect())
Serial.println("EasyVR not detected!");
for (;;);
easyvr.setPinOutput(EasyVR::IO1, LOW);
Serial.println("EasyVR detected!");
easyvr.setTimeout(5);
easyvr.setLanguage(0);
group = EasyVR::TRIGGER; //<-- start group (customize)
void action();
easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
Serial.print("Say a command in Group ");
Serial.println(group);
easyvr.recognizeCommand(group);
do
// can do some processing while waiting for a spoken command
while (!easyvr.hasFinished());
easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
idx = easyvr.getWord();
if (idx >= 0)
// built-in trigger (ROBOT)
// group = GROUP_X; <-- jump to another group X
return;
idx = easyvr.getCommand();
if (idx >= 0)
// print debug message
uint8_t train = 0;
char name[32];
Serial.print("Command: ");
Serial.print(idx);
if (easyvr.dumpCommand(group, idx, name, train))
Serial.print(" = ");
Serial.println(name);
easyvr.playSound(0, EasyVR::VOL_FULL);
// perform some action
action();
else // errors or timeout
if (easyvr.isTimeout())
Serial.println("Timed out, try again...");
int16_t err = easyvr.getError();
if (err >= 0)
Serial.print("Error ");
Serial.println(err, HEX);
void action()
switch (group)
case GROUP_0:
switch (idx)
case G0_ANNA:
// write your action code here
// group = GROUP_X; <-- or jump to another group X for composite commands
group = GROUP_1;
case GROUP_1:
switch (idx)
case G1_GREEN_LED:
goto ledloop;
void ledloop() {
// set the brightness of pin 9:
analogWrite(led, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness == 0 || brightness == 255) {
fadeAmount = -fadeAmount ;
// wait for 30 milliseconds to see the dimming effect
delay(30);
