need help using floatValues with touchOSC
so i am trying to control my arduino from my iphone wirelessly using touchOSC and a ethernet shield and the OSCClass library.
i loaded up the sample code and can not get it to turn on the leds. my ethernet board says its receiving but nothing else is happening. i am assuming it is because it uses iOSC instead of touchOSC and that it uses int instead of float. but changing recMes.getArgInt to recMes.getArgFloat doesnt work.
here is the code
// OSCClass iOSC(iPhone App) test sketch
// OSCClass version 1.0.1 (Arduino ver0014)
// Copyright (c) recotana(http://recotana.com).  All right reserved.
iOSC is OSCsend Application for iPhone
http://recotana.com/iphone/iosc/
iOSC setting
            OSCMessage    type  value on  off
button1    /ard/ledyel    int          1   0   :info-AlternateMode "ON" =toggle sw
button2    /ard/ledgrn    int          1   0
button3    /ard/ledred    int          1   0
slider1    /ard/ledpwm    int  min:0 max:255
host setting IP address 192.168.0.99 , port 10000
#include "Ethernet.h"
#include "OSCClass.h"
#define  LED_RED 2
#define  LED_GRN 3
#define  LED_YEL 4
#define  LED_PWM 6
  OSCMessage recMes;
  OSCClass osc(&recMes);
  byte serverMac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
  byte serverIp[]  = { 192, 168, 0, 99 };
  int  serverPort  = 10000;
//  byte gateway[]   = { 192, 168, 0, 1 };
//  byte subnet[]    = { 255, 255, 255, 0 };
  char *topAddress="/ard";
  char *subAddress[4]={ "/ledred" , "/ledgrn" , "/ledyel" , "/ledpwm"};
       //for message logging
//     Serial.begin(19200);
      Ethernet.begin(serverMac ,serverIp);
 //    Ethernet.begin(serverMac ,serverIp ,gateway ,subnet);
     //setting osc recieve server
     osc.begin(serverPort);
     pinMode(LED_RED, OUTPUT);
     pinMode(LED_GRN, OUTPUT);
     pinMode(LED_YEL, OUTPUT);
     pinMode(LED_PWM, OUTPUT);
     digitalWrite(LED_RED, HIGH);  //LED OFF
     digitalWrite(LED_GRN, HIGH);  //LED OFF
     digitalWrite(LED_YEL, HIGH);  //LED OFF
     digitalWrite(LED_PWM, HIGH);  //LED OFF
    //osc message buffer clear
     osc.flush();
    //osc arrive check
    if ( osc.available() ) {
//logMessage(&recMes);
          //toplevel address matching
          if( !strcmp( recMes.getAddress(0) , topAddress ) ){
              //second level address matching
                if( !strcmp( recMes.getAddress(1) , subAddress[0] ) ){
                      red();
                else if( !strcmp( recMes.getAddress(1) , subAddress[1] ) ){
                      green();
                else if( !strcmp( recMes.getAddress(1) , subAddress[2] ) ){
                      yellow();
                else if( !strcmp( recMes.getAddress(1) , subAddress[3] ) ){
                      pwm();
void red(){
   if(recMes.getArgInt(0) == 1){
          digitalWrite(LED_RED, LOW);  //LED_ON
   else{
void green(){
          digitalWrite(LED_GRN, LOW);  //LED_ON
   else{
void yellow(){
          digitalWrite(LED_YEL, LOW);  //LED_ON
   else{
void pwm(){
  byte value=(byte)recMes.getArgInt(0);
  analogWrite(LED_PWM, 255-value);
// *********  utility  ***********************************
void logMessage(OSCMessage *mes){
    uint8_t *ip=mes->getIp();
     //disp ip & port
    Serial.print("from IP:");
    Serial.print(ip[0],DEC);
    Serial.print(".");
    Serial.print(ip[1],DEC);
    Serial.print(".");
    Serial.print(ip[2],DEC);
    Serial.print(".");
    Serial.print(ip[3],DEC);
    Serial.print(" port:");
    Serial.print(mes->getPort(),DEC);
    Serial.print("   ");
    //disp adr
    for(int i = 0 ; i < mes->getAddressNum() ; i++){
      Serial.print(mes->getAddress(i));
    //disp type tags
    Serial.print("  ,");
    for(int i = 0 ; i < mes->getArgNum() ; i++){
      Serial.print(mes->getTypeTag(i));
    Serial.print(" ");
   //disp args
      switch( mes->getTypeTag(i) ){
        case 'i': {
                      Serial.print( mes->getArgInt(i) );
        case 'f':  {
                      Serial.print( mes->getArgFloat(i) );
       Serial.print(" ");
    Serial.println("");
Use code tags instead of quote tags
e.g.
iOSC setting
#define  LED_RED 2
#define  LED_GRN 3
#define  LED_YEL 4
#define  LED_PWM 6
  OSCMessage recMes;
     osc.flush();
    //osc arrive check
                      red();
                      green();
                      yellow();
                      pwm();
void red(){
   else{
void green(){
   else{
void yellow(){
   else{
void pwm(){
     //disp ip & port
    Serial.print(".");
    Serial.print(".");
    Serial.print(".");
    Serial.print("   ");
    //disp adr
    //disp type tags
    Serial.print("  ,");
    Serial.print(" ");
   //disp args
        case 'i': {
        case 'f':  {
       Serial.print(" ");
    Serial.println("");
Please link to these items and also link to the library you are using
iOSC iOSC
touchOSC TouchOSC | hexler.net
tried ardOSC library http://recotana.com/recotanablog/closet
and oscclass library http://forum.arduino.cc/index.php/topic,38015.0.html
I recently wrote a little tutorial on My TrippyLighting blog that explains how to exchange messages with TouchOSC, including code and a TouchOSC layout.
