need help using rtc
hello all this is my first project using arduino uno,and pls forgive my super English skills.
i am making a timer switch using rtcDS3231 , relay module and a 20x4 lcd using i2c.
i have written a program to start a relay at certain time and turn it off ,
but my problem is when the relay is on at given time but when power goes off and comes back mean it is not turning on
Example:-
i programmed to on on 6am in morning and turn off at 4pm , if the power goes off in between the on time it is not turning of after the power comes
my code follows:
#include <TimeLib.h>
#include <Wire.h>
#include “RTClib.h”
LiquidCrystal_I2C lcd(0x27,20,4);
RTC_DS1307 RTC;
void setup () {
Wire.begin();
RTC.begin();
lcd.init(); // initialize the lcd
lcd.backlight();
if (! RTC.isrunning())
Serial.println(“RTC is NOT running!”);
//Any pin. I have used Pin 4
pinMode(4, OUTPUT);
void loop () {
DateTime now = RTC.now();
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(now.year(), DEC);
lcd.print(’/’);
lcd.print(now.month(), DEC);
lcd.print(’/’);
lcd.print(now.day(), DEC);
lcd.setCursor(0, 1);
lcd.print(now.hour(), DEC);
lcd.print(’:’);
lcd.print(now.minute(), DEC);
lcd.print(’:’);
lcd.print(now.second(), DEC);
if (now.hour() == 6 && now.minute() == 10& now.second() == 0)
digitalWrite(4,1);
else if (now.hour() == 16 & now.minute() == 0 & now.second() == 0)
digitalWrite(4, 0);
please help meeeeeeeeee
      digitalWrite(4,1);
      digitalWrite(4, 0);
I don't know what your fascination with useless white space is, but, this is the code that diddles with the relay. Note that it does NOT turn the relay on anytime between 6:10 and 16:00. It (tries to) turn the relay on AT 6:10, and off AT 16:00.
First, you need to use && everywhere. Second you need to turn the pin on when the time is greater than or equal to 6:10 and less than or equal 16:00.
please teach me or give an example
PaulS:
      digitalWrite(4,1);
      digitalWrite(4, 0);
First, you need to use && everywhere. Second you need to turn the pin on when the time is [u]greater than or[/u] equal to 6:10 [u]and less than or[/u] equal 16:00.
give an example
   if(now.hour() >= 6 && now.minute() >= 10 && now.hour() < 16)
      digitalWrite(relayPin, HIGH);
      digitalWrite(relayPin, LOW);
i need to make a planted aquarium so i need a timer switch code
I have no idea what this statement means, in relation to the code you posted.
syedthedevil:
The switching conditions you are using are only working if the device is powered-on at that time and you pass the exact switching time.
Alternative switching logic:
int minuteToday=now.hour() *60 + now.minute();
byte onState= (minuteToday>=6*60+10) && (minuteToday<16*60); // on from 06:10 until 15:59
digitalWrite(4,onState);
sorry but can u explain me the code
PaulS:
No. There is nothing to explain. Look up, on the reference page, any part that is not clear.
thank you thank you thank you
the code works :smiley:
and i can understand the code(so simple and perfect)
