Need Help Using Thermocouple with MAX6675
I'm a newbie and I'm trying to use the MAX6675 with a K type TC, both of which I purchases from sparkfun, but I've got no clue where to begin to write the code to read the SPI from the MAX6675. I read through the SPI EEPROM tutorial and that a bit over my head. Has anyone else accomplished this, and if so, may I see the code that you used for this or for any other similar SPI read only sensor? Please?
Here is some code that reads a DS1722 temperature sensor, which is an SPI device. Not sure if the Dallas and Maxim protocols are similar, but it's an SPI example, anyway.
-j
#define DATAOUT 11 //MOSI
#define DATAIN  12 //MISO
#define SPICLOCK  13 //sck
#define SLAVESELECT 10 //ss
#define DS1722_POWER 9
#define DS1722_SELECT HIGH
#define DS1722_DESELECT LOW
#define DS1722_CONFIG_BYTE 0xEE
#define CONFIG_REG_READ 0x00
#define CONFIG_REG_WRITE 0x80
#define TEMP_ADDR_HI 0x02
#define TEMP_ADDR_LOW 0x01
byte clr;
byte temperature[2];
char spi_transfer(volatile char data)
  SPDR = data;                    // Start the transmission
  while (!(SPSR & (1<<SPIF)))     // Wait the end of the transmission
  return SPDR;                    // return the received byte
  byte n;
  byte config = 0xAB;
  temperature[0]=0x12;
  temperature[1]=0x34;
  pinMode(DATAOUT, OUTPUT);
  pinMode(DATAIN, INPUT);
  pinMode(SPICLOCK, OUTPUT);
  pinMode(SLAVESELECT, OUTPUT);
  pinMode(DS1722_POWER, OUTPUT);
  digitalWrite(DS1722_POWER, HIGH); //disable device
  delay(250);
  digitalWrite(SLAVESELECT, DS1722_DESELECT); //disable device
  // set up SPI control register
  SPCR = (1<<SPE)|(1<<MSTR)|(1<<CPOL)|(1<<CPHA);
  clr=SPSR;
  clr=SPDR;
  delay(10);
  // read config byte
  digitalWrite(SLAVESELECT, DS1722_SELECT);
  spi_transfer(CONFIG_REG_READ);
  config = spi_transfer(0xFF);
  delay(100);
  Serial.print(config, HEX);
  Serial.print('\n', BYTE);
  // write config byte to the configuration register
  spi_transfer(CONFIG_REG_WRITE);
  spi_transfer(DS1722_CONFIG_BYTE);
  delay(100);
  // read config byte
  delay(100);
  Serial.print('h', BYTE);
  Serial.print('i', BYTE);
  Serial.print('\n', BYTE);//debug
//  float c, f;
  delay(1400);
  digitalWrite(SLAVESELECT,DS1722_SELECT);
  spi_transfer(TEMP_ADDR_HI);
  temperature[0] = spi_transfer(0x00);
  digitalWrite(SLAVESELECT, DS1722_DESELECT); //release chip, signal end transfer
  delay(25); // just because....
  spi_transfer(TEMP_ADDR_LOW);
  temperature[1] = spi_transfer(0x00);
  Serial.print(temperature[0] * 9 / 5 + 32, DEC);
  Serial.print(' ', BYTE);
  Serial.print(temperature[0], DEC);
  if(temperature[1] & 0x80)
    Serial.print( '.', BYTE);
    Serial.print( '5', BYTE);
  Serial.print('\r', BYTE);
  delay(2000);
