need help where did i go wrong with my sketch!?!?!?!
Hey guys im having an issue with my code. starting off my uno enters power down sleep after the short delay. If i press the downbutton (pin2) uno wakes up and relay 3/4 come on like normal but relay 1 only stays on about 1 second even tho the delay says 5. uno goes back to sleep like i want then i hit the upbutton(pin3) and relay 2 turns on with 5 second delay. uno goes back to sleep but how do i keep the loop going, my interrupt buttons will not wake the uno from this point on, I need to reload the sketch to reset. Thanks in advance for the help.
#include <avr/interrupt.h>
#include <avr/power.h>
#include <avr/sleep.h>
#include <avr/io.h>
// constants won't change.
const int downbutton = 2;     // downbutton to pin 2
const int upbutton = 3;       // upbutton to pin 3
const int relay1 =  7;       // relay1 to pin
const int relay2 =  6;       // relay2 to pin
const int relay3 =  5;        // relay3 to pin
const int relay4 =  4;        // relay4 to pin
// variables will change:
int buttonState2 = 0;         // variable for reading the pushbutton status
int buttonState3 = 0;
void setup(){
    DDRD &= B00000011;       // set Arduino pins 2 to 7 as inputs, leaves 0 & 1 (RX & TX) as is
    DDRB = B00000000;        // set pins 8 to 13 as inputs
    PORTD |= B11111100;      // enable pullups on pins 2 to 7
    PORTB |= B11111111;      // enable pullups on pins 8 to 13
    pinMode(13,OUTPUT);      // set pin 13 as an output so we can use LED to monitor
    digitalWrite(13,HIGH);   // turn pin 13 LED on
    pinMode(upbutton, INPUT);        // sets the downbutton pin as input
    pinMode(downbutton, INPUT);      // sets the downbutton pin as input
    pinMode(relay1, OUTPUT);      // sets the relay pin as output
    pinMode(relay2, OUTPUT);      // sets the relay pin as output
    pinMode(relay3, OUTPUT);      // sets the relay pin as output
    pinMode(relay4, OUTPUT);      // sets the relay pin as output
    digitalWrite(relay1, LOW);    // Prevents relays from starting up engaged
    digitalWrite(relay2, LOW);    // Prevents relays from starting up engaged
    digitalWrite(relay3, LOW);    // Prevents relays from starting up engaged
    digitalWrite(relay4, LOW);    // Prevents relays from starting up engaged
void loop(){
   // Stay awake for 1 second, then sleep.
    // LED turns off when sleeping, then back on upon wake.
    delay(5000);
    sleepNow();
void sleepNow(void)
    // Set pin 2/3 as interrupt and attach handler:
    attachInterrupt(0, pinInterrupt, HIGH);
    attachInterrupt(1, pinInterrupt, HIGH);
    // Choose our preferred sleep mode:
    set_sleep_mode(SLEEP_MODE_PWR_DOWN);
    // Set sleep enable (SE) bit:
    sleep_enable();
    // Put the device to sleep:
    digitalWrite(13,LOW);   // turn LED off to indicate sleep
    sleep_mode();
    // Upon waking up, sketch continues from this point.
    sleep_disable();
    digitalWrite(13,HIGH);   // turn LED on to indicate awake
void pinInterrupt(void)
    detachInterrupt(0);
    detachInterrupt(1);
   buttonState3 = digitalRead(upbutton);  // read the state of the upbutton value
   buttonState2 = digitalRead(downbutton); // read the state of the downbutton value
  // check whether a  pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState2 == HIGH) {
    // turn relay 1 on:
     digitalWrite(relay3, HIGH); digitalWrite(relay4, HIGH); digitalWrite(relay1, HIGH);
    // wait for 5 seconds
    delay(5000);
  if (buttonState2 == LOW || buttonState3 == LOW) {
    // relay 1,2 off
  if (buttonState3 == HIGH) {
    // turn relay 2 on:
    digitalWrite(relay3, LOW); digitalWrite(relay4, LOW); digitalWrite(relay2, HIGH);
    delay(5000);
I guess my issue now is how do i reset the interrupt.
