I am new to coding and Arduino's and I'm making a sim racing wheel and connect it to my computer and i keep getting a error with peoples code and even with joystick lib driving controller example code on my Leonardo and the error is:
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:11:1: error: 'Joystick_' does not name a type; did you mean 'Joystick'?
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
Joystick
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino: In function 'void testSingleButtonPush(unsigned int)':
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:30:13: error: expected unqualified-id before '.' token
Joystick.releaseButton(button - 1);
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:34:13: error: expected unqualified-id before '.' token
Joystick.pressButton(button);
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino: In function 'void testMultiButtonPush(unsigned int)':
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:46:17: error: expected unqualified-id before '.' token
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:49:17: error: expected unqualified-id before '.' token
Joystick.releaseButton(button);
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:56:17: error: expected unqualified-id before '.' token
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:59:17: error: expected unqualified-id before '.' token
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:64:15: error: expected unqualified-id before '.' token
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino: In function 'void testAcceleratorBrake(int)':
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:71:11: error: expected unqualified-id before '.' token
Joystick.setAccelerator(value);
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:72:11: error: expected unqualified-id before '.' token
Joystick.setBrake(260 - value);
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino: In function 'void testSteering(int)':
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:78:13: error: expected unqualified-id before '.' token
Joystick.setSteering(value);
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:80:13: error: expected unqualified-id before '.' token
Joystick.setSteering(600 - value);
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino: In function 'void setup()':
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:86:11: error: expected unqualified-id before '.' token
Joystick.setAcceleratorRange(0, 260);
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:87:11: error: expected unqualified-id before '.' token
Joystick.setBrakeRange(0, 260);
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:88:11: error: expected unqualified-id before '.' token
Joystick.setSteeringRange(0, 300);
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:92:13: error: expected unqualified-id before '.' token
Joystick.begin();
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:96:13: error: expected unqualified-id before '.' token
Joystick.begin(false);
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino: In function 'void loop()':
C:\Users\rexim\AppData\Local\Temp\822db133-87a6-41cb-b33e-234bfbeeee2a_ArduinoJoystickLibrary-version-2.0.zip.e2a\ArduinoJoystickLibrary-version-2.0\examples\DrivingControllerTest\DrivingControllerTest.ino:142:15: error: expected unqualified-id before '.' token
Joystick.sendState();
exit status 1
Compilation error: 'Joystick_' does not name a type; did you mean 'Joystick'?
