L298N Motor Control with Flysky6
// Motor A Drive
int enA = 11;
int in1 = 10;
int in2 = 9;
// Motor B Drive
int enB = 6;
int in3 = 8;
int in4 = 7;
// Motor C Dome
int enC = 5;
int in5 = 4;
int in6 = 3;
// Joystick Input
int joyDriveA = A0; // Vertical
int joyDriveB = A1; // Horizontal
int joyDome = A2; // DOME
// Motor Speed Values - Start at zero
int MotorSpeed1 = 0;
int MotorSpeed2 = 0;
int MotorSpeed3 = 0;
// Joystick Values - Start at 512 (middle position)
int joyposVert = 512;
int joyposHorz = 512;
int joyposDome = 512;
// Set all the motor control pins to outputs
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(enC, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(in5, OUTPUT);
pinMode(in6, OUTPUT);
// Start with motors disabled and direction forward
// Motor A
digitalWrite(enA, LOW);
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
// Motor B
digitalWrite(enB, LOW);
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
// Motor C Dome
digitalWrite(enC, LOW);
digitalWrite(in5, HIGH);
digitalWrite(in6, LOW);
// Read the Joystick X and Y positions
joyposVert = analogRead(joyDriveA);
joyposHorz = analogRead(joyDriveB);
joyposDome = analogRead(joyDome);
// Determine if this is a forward or backward motion
// Do this by reading the Verticle Value
// Apply results to MotorSpeed and to Direction
if (joyposVert < 460)
// This is Backward
// Set Motor A backward
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
// Set Motor B backward
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
//Determine Motor Speeds
// As we are going backwards we need to reverse readings
joyposVert = joyposVert - 460; // This produces a negative number
joyposVert = joyposVert * -1; // Make the number positive
MotorSpeed1 = map(joyposVert, 0, 460, 0, 255);
MotorSpeed2 = map(joyposVert, 0, 460, 0, 255);
else if (joyposVert > 564)
// This is Forward
// Set Motor A forward
// Set Motor B forward
MotorSpeed1 = map(joyposVert, 564, 1023, 0, 255);
MotorSpeed2 = map(joyposVert, 564, 1023, 0, 255);
// This is Stopped
MotorSpeed1 = 0;
MotorSpeed2 = 0;
// Now do the steering
// The Horizontal position will "weigh" the motor speed
// Values for each motor
if (joyposHorz < 460)
// Move Left
// As we are going left we need to reverse readings
joyposHorz = joyposHorz - 460; // This produces a negative number
joyposHorz = joyposHorz * -1; // Make the number positive
// Map the number to a value of 255 maximum
joyposHorz = map(joyposHorz, 0, 460, 0, 255);
MotorSpeed1 = MotorSpeed1 - joyposHorz;
MotorSpeed2 = MotorSpeed2 + joyposHorz;
// Don't exceed range of 0-255 for motor speeds
if (MotorSpeed1 < 0)MotorSpeed1 = 0;
if (MotorSpeed2 > 255)MotorSpeed2 = 255;
else if (joyposHorz > 564)
// Move Right
joyposHorz = map(joyposHorz, 564, 1023, 0, 255);
MotorSpeed1 = MotorSpeed1 + joyposHorz;
MotorSpeed2 = MotorSpeed2 - joyposHorz;
if (MotorSpeed1 > 255)MotorSpeed1 = 255;
if (MotorSpeed2 < 0)MotorSpeed2 = 0;
// Now do the Dome
// The Chan3 position will "control the dome Clockwise and counter Clockwise
if (joyposDome < 460)
// This is CounterClock
// Set Dome CounterClock
digitalWrite(in5, LOW);
digitalWrite(in6, HIGH);
// As we are going CouterClock we need to reverse readings
joyposDome = joyposDome - 460; // This produces a negative number
joyposDome = joyposDome * -1; // Make the number positive
MotorSpeed3 = map(joyposDome, 0, 460, 0, 70);
else if joyposDome > 564)
// This is Clockwise
// Set Dome Clockwise
MotorSpeed3 = map(joyposDome, 564, 1023, 0, 70);
// This is Stopped
MotorSpeed3 = 0;
// Adjust to prevent "buzzing" at very low speed
if (MotorSpeed1 < 8)MotorSpeed1 = 0;
if (MotorSpeed2 < 8)MotorSpeed2 = 0;
if (MotorSpeed3 < 8)MotorSpeed3 = 0;
// Set the motor speeds
analogWrite(enA, MotorSpeed1);
analogWrite(enB, MotorSpeed2);
analogWrite(enC, MotorSpeed3);
