Need help with a make file, please
I am trying to compile a hex file on a PC for a Wixel device that will be connected to an Arduino (Tx, Rx).
I have never compiled a C program and the make command is giving me an error:
Compiling apps/dexdrip/dexdrip.rel
(null):2: syntax error: token -> ':' ; column 2
sdcpp.exe: fatal error: when writing output to : Invalid argument
make: *** [apps/dexdrip/dexdrip.rel] Error 1
You may now close this window.
I am absolutely clueless. Any assistance would be appreciated.
I posted an issue on Github, but the last update to the repository was 7 years ago, and there are open issues from 2014, so expecting a response from the repository owner is next to hopeless. I am hoping that someone with more C experience might be able to help.
Here is the makefile
# This is Makefile defines how to compile all of the libraries and applications
# in the SDK.
# See README.txt for instructions on how to get started using this SDK.
# type `make` or `make apps` to make all of the apps in the apps folder
# type `make APPNAME` to make a specific app
# type `make libs` to make all the libraries
.DEFAULT_GOAL := apps
#### Programs used by this Makefile ############################################
CC := sdcc#         C compiler: creates object files (.rel) from C files (.c)
AS := sdas8051#     Assembler:  creates object files (.rel) from assembly files (.s)
AR := sdcclib#      Librarian:  creates .lib
LD := sdld#         Linker:     creates .hex files from .rel/.lib files)
PACKIHX := packihx# makes .hex files smaller
MV := move#         moves files
CP := cp#           copies files
CAT := cat#         outputs files
ECHO := echo#       outputs some text to the standard output
GREP := grep#       outputs lines from a file that match a given pattern
SED := sed#         edits files
WIXELCMD := wixelcmd# loads programs on the Wixel (command-line utility)
WIXELCONFIG := wixelconfig # Wixel Configuration Utility (GUI)
#### Include directories #######################################################
INCDIRS += libraries/include
I_FLAGS = $(patsubst %,-I%,$(INCDIRS))
#### Compilation options #######################################################
# Generate dependency information
C_FLAGS += -Wp,-MD,$(@:%.rel=%.d),-MT,$@,-MP
# Disable warning 110: conditional flow changed by optimizer
WARNING := --disable-warning 110
C_FLAGS += $(WARNINGS)
# Add the include directories
C_FLAGS += $(I_FLAGS)
# Disable pagination in .lst file
C_FLAGS += -Wa,-p
AS_FLAGS += -p
# Put the output in the right place.
PPC_FLAGS += -Wp,-o,$@
MODEL = --model-medium
C_FLAGS += $(MODEL)
LD_FLAGS += $(MODEL)
# Generate debugging information (.cdb files).
C_FLAGS += --debug
LD_FLAGS += --debug
#### Code area options #########################################################
# --code-loc  corresponds to the "-b HOME =" linker argument
# --code-size corresponds to the "-w" argument to the linker
# CODE_AREA_FULL: Uses all 32k on the chip.
CODE_AREA_FULL = --code-loc 0x0000 --code-size 0x8000
# CODE_AREA_APP: Creates an application that can be loaded with the bootloader,
# using only kilobytes 1-29 inclusive.
CODE_AREA_APP = --code-loc 0x0400 --code-size 0x7400
# The default code area is CODE_AREA_APP.
CODE_AREA := $(CODE_AREA_APP)
LD_FLAGS += $(CODE_AREA)
#### Linking options ###########################################################
# The size of internal ram.  ("-a" argument to the linker)
LD_FLAGS += --iram-size 0x0100
# XRAM location.  ("-b XSEG =" and "-b PSEG =" arguments to linker)
LD_FLAGS += --xram-loc 0xF000
# XRAM size. ("-v" argument to linker)
LD_FLAGS += --xram-size 0xF00
LD_FLAGS += -o $(@:%.hex=%.ihx)
#### MODULES ###################################################################
TARGETS :=
RELs :=
LIBs :=
HEXs :=
include libraries/libs.mk
include apps.mk
#### FILES TYPES ###############################################################
# .c   : This is a file that contains source code in the C language.
# .h   : Header file in the C language (part of the source code).
# .s   : Assembly language source code.
# .rel : This is an Object file, the result of compiling a .s or .c file.
# .lib : This is a library (a collection of several object files).
# .hex : This is a complete program that can be loaded onto a Wixel.
# The lists of all .rel/lib/hex files compiled by this Makefile are in the
# following variables: $(RELs) $(LIBs) $(HEXs)
# These files are generated when compiling a .c file.
Ds := $(RELs:%.rel=%.d)      # .d : dependency information
CDBs := $(RELs:%.rel=%.cdb)  # .cdb : debugging information
ADBs := $(RELs:%.rel=%.adb)  # .adb : debugging information
ASMs := $(RELs:%.rel=%.asm)  # .asm : assembly generated by compiler
# These files are generated when compiling a .s or .c file.
SYMs := $(RELs:%.rel=%.sym)  # .sym : symbol table
LSTs := $(RELs:%.rel=%.lst)  # .lst : listing without absolute addresses
RSTs := $(RELs:%.rel=%.rst)  # .rst : listing with absolute addresses
# These files are generated when linking:
MEMs := $(HEXs:%.hex=%.mem)  # .mem : summary of memory usage
MAPs := $(HEXs:%.hex=%.map)  # .map : list of all addresses and memory sections
LKs  := $(HEXs:%.hex=%.lk)   # .lk  : args used by the linker
LNKs := $(HEXs:%.hex=%.lnk)  # .lnk : args used by the linker (prior to SDCC 3.1.0)
CDBs := $(HEXs:%.hex=%.cdb)  # .cdb : debugging information
OMFs := $(HEXs:%.hex=%) $(HEXs:%.hex=%.omf) # .omf : had no extension prior to SDCC 3.1.0
# These files can be generated from a .hex and .cdb file.
WXLs := $(HEXs:%.hex=%.wxl)  # .wxl : Wixel application
WXLs += $(HEXs:%.hex=%.wxl.tmp)
#### TARGETS ###################################################################
TARGETS += $(RELs) $(HEXs) $(LIBs)
all: $(TARGETS) apps
.PHONY: clean
clean:
	-@rm -fv $(TARGETS)
	-@rm -fv $(CLEAN)
	-@rm -fv $(Ds)
	-@rm -fv $(SYMs)
	-@rm -fv $(CDBs)
	-@rm -fv $(MEMs)
	-@rm -fv $(RSTs)
	-@rm -fv $(MAPs)
	-@rm -fv $(LSTs)
	-@rm -fv $(LKs)
	-@rm -fv $(LNKs)
	-@rm -fv $(BINs)
	-@rm -fv $(ASMs)
	-@rm -fv $(OMFs)
	-@rm -fv $(ADBs)
	-@rm -fv $(CDBs)
	-@rm -fv $(WXLs)
#### COMPLETE COMMANDS #########################################################
ifdef VERBOSE
COMPILE_COMMAND  = $(CC) -c $< $(C_FLAGS) -o $@
ASSEMBLE_COMMAND = $(AS) -glos $(AS_FLAGS) $<
ARCHIVE_COMMAND  = $(AR) $@ $^
LINK_COMMAND     = $(CC) $(LD_FLAGS) libraries/xpage/xpage.rel $^
V=@
COMPILE_COMMAND  = @echo Compiling  $@ && $(CC) -c $< $(C_FLAGS) -o $@
ASSEMBLE_COMMAND = @echo Assembling $@ && $(AS) -glos $(AS_FLAGS) $<
ARCHIVE_COMMAND  = @echo Creating   $@ && $(AR) $@ $^
LINK_COMMAND     = @echo Linking    $@ && $(CC) $(LD_FLAGS) libraries/xpage/xpage.rel $^
endif
#### IMPLICIT RULES ############################################################
%.rel: %.c
	$(COMPILE_COMMAND)
%.rel: %.s
	$(ASSEMBLE_COMMAND)
%.lib:
	$(V)rm -f $@
	$(ARCHIVE_COMMAND)
#%.hex: %.rel
#   $(LINK_COMMAND)
#	@mv -f $(@:%.hex=%.ihx) $@
%.wxl: %.hex
	@echo Packaging  $@
	$(V)$(ECHO) Pololu Wixel Application - www.pololu.com> $@.tmp
	$(V)$(ECHO) 1.0>> $@.tmp
	$(V)$(ECHO) ====== license>> $@.tmp
	$(V)$(CAT) LICENSE.txt >> $@.tmp
	$(V)$(ECHO) ====== cdb>> $@.tmp
	$(V)$(GREP) param $(<:%.hex=%.cdb) >> $@.tmp || echo "(This app has no params.)"
	$(V)$(ECHO) ====== hex>> $@.tmp
	$(V)$(PACKIHX) $< >> $@.tmp
	$(V)$(SED) -f libraries/dos_newlines.sed $@.tmp > $@
	$(V)$(RM) $@.tmp
# Include all the dependency files generated during compilation so that Make
# knows which .rel files to recompile when a .h file changes.
-include $(Ds)
Did you try to type make clean before typing make all?
Could also be some outdated sdcpp stuff…
Thanks. make clean didn't change the results.
Outdated- most likely. The newest files on the git are 5 years old, and not knowing what I'm doing, I just followed the steps in the readme.md file.
Here is where sdcc got installed:
  ##### ON WINDOWS
  * Install the wixel development bundle for windows from [here](http://www.pololu.com/file/0J526/wixel-dev-bundle-120127.exe) (you need this in addition to the drivers you downloaded in step 2!!)
  * Open a command prompt (should be under start menu -> programs -> accessories -> Command Prompt)
  * Cd into the folder you downloaded this repo to (ex. `cd C:\Users\<computer name>\Desktop\wixel-xDrip`)
  * now run `make_all.bat` by typing `make_all.bat` into the command prompt
I bought the Wixel device from Pololu, so I should probably ask them...
What’s in the make_all.bat file?
Not much. Just make.
@echo off
make
echo You may now close this window.
pause > nul
I Wonder If this is not due to a missing working path definition or something like that since it seeems file names are missing in the error message…
