Need help with a rotary encoder
Hello! This is my first post on this forum.
I have some trouble with a rotary encoder. My current project is making a menu system with submenus that is controlled using a rotary encoder and displayed on a 16x2 LCD screen. The problem is that I tried using a loading variable (currentMenu in the code below) that should act as check for the current menu I am in. However, printing the value through serial shows me that whenever I press the button, currentMenu resets back to 0 and I cannot cycle through any of the submenu's options. Can you please help me?
This is my code (the menu options are written in Romanian, but that should not be a problem for reading):
#include <LiquidCrystal.h>
#include <rotary.h>                 // rotary handler
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#define A_output 9
#define B_output 8
#define SW_output 7
Rotary r = Rotary(A_output, B_output, SW_output);
int currentMenu;
int columns = 16;
char *menuList[] = {"Motoare", "Contrast", "LED Test", "Opt. lumina", "Despre", "Resetare"};
char *menuListMotor[] = {"Servo1", "Servo2"};
char *menuListOpts[] = {"Pornit", "Oprit"};
int menuItems = 6;
int menuItemsMotor = 2;
int menuItemsOpts = 2;
int CursorLine = 0;
int CursorLineMotor = 0;
int CursorLineContrast = 0;
int ledPin = 4;
int backButton = 2;
int contrastLevel = 10;
int backlightPin = 10;
int brightness = 255;
int fadeLevel = 5;
void (*resetfunc)(void) = 0;
void setup ()
  digitalWrite(A_output, HIGH);
  digitalWrite(B_output, HIGH);
  digitalWrite(SW_output, HIGH);
  analogWrite(backlightPin, brightness);
  analogWrite(6, contrastLevel);
  pinMode(backButton, INPUT);
  pinMode(ledPin, OUTPUT);
  lcd.clear();
  lcd.begin(16, 2);
  lcd.print("  Bun venit! :)");
  delay(2000);
  print_menu();
  currentMenu = 0;
} //end of setup
void loop ()
  if (currentMenu == 0) {
    menu_system();
  } else if (currentMenu == 1) {
    motor_system();
  Serial.println(currentMenu);
} //End loop()
void menu_system() {
  volatile unsigned char result = r.process();
  if (result) {
    result == DIR_CCW ? CursorLine = CursorLine - 1 : CursorLine = CursorLine + 1;
    if (CursorLine < 0) {
      CursorLine = 0;
    } else if (CursorLine > menuItems - 1) {
      CursorLine = menuItems - 1;
    print_menu();
  if (r.buttonPressedReleased(25)) {
    lcd.setCursor(0, 0);  //(col, row)
    lcd.setCursor(0, 1);  //(col, row)
    selection();
  } //endif buttonPressedReleased
void motor_system() {
  int valueMenu = digitalRead(backButton);
  if (result) {
    result == DIR_CCW ? CursorLineMotor = CursorLineMotor - 1 : CursorLineMotor = CursorLineMotor + 1;
    if (CursorLineMotor < 0) {
    } else if (CursorLineMotor > menuItems - 1) {
      CursorLineMotor = menuItems - 1;
    contrast_menu();
    selection_motor();
  if (valueMenu == LOW) // if button is pressed, turn LED on
    lcd.print("Iesire");
    currentMenu = 0;
void print_menu()
  lcd.clear();
  lcd.print("  Meniu simplu  ");
  lcd.setCursor(0, 1);    //2nd row
  lcd.print("<"); lcd.setCursor(columns - 1, 1); lcd.print(">");
  lcd.setCursor(1, 1);
  lcd.print(menuList[CursorLine]);
void contrast_menu() {
  lcd.clear();
  lcd.print("Selectie motor");
  lcd.print(menuList[CursorLineMotor]);
void selection()
  switch (CursorLine) {
    case 0:
      currentMenu = 1;
      contrast_menu();
    case 1:
    case 2:
      //set a flag or do something....
      lcd.print("Testare LED!      ");
      lcd.print("                     ");
      digitalWrite(ledPin, HIGH);
      digitalWrite(ledPin, LOW);
      print_menu();
    case 3:
      lcd.print("Lumina de spate    ");
      digitalWrite(backlightPin, LOW);
    case 4:
      lcd.print("Built at    (C) ");
      lcd.print("FalconVille 2021");
      delay(3000);
      print_menu();
    case 5:
      lcd.print("Resetare...       ");
      lcd.print("                    ");
      delay(2000);
      resetfunc();
  } //end switch
  //delay(2000);
  //CursorLine = 0;     // reset to start position
} //End selection
void selection_motor() {
  switch (CursorLineMotor) {
    case 0:
      //turn on servo 1
    case 1:
      //turn on servo 2
    default:
Also, here is the rotary library that I used (This is a version made specifically to make the encoder's button work):
https://easyupload.io/d1v89o
Hi @goteki45,
I tried to run your code, but I couldn't find the library "rotary.h" with a lowercase "r".
I only found it with "R" uppercase.
Can you send me a link to your library?
RV mineirin
Hello, sorry for the late response.
I left a link to my library in the original post.
Here is an update to my code. I optimized it by including 2 bool variables that change whenever I switch to a submenu.And it works!
However, when I switch to the second menu, both lists of options change, and then both menus are filled with garbage memory if I scroll past the last option.
#define A_output 9
#define B_output 8
#define SW_output 7
int currentMenu;
int columnsLCD = 16;
char *MenuItems[] = {"Motoare", "Contrast", "LED Test", "Opt. lumina", "Despre", "Resetare"};
char *SubMenuItems[] = {"Servo1", "Servo2", "Iesire"};
int menuItems = 6;
int subMenuItems = 2;
int CursorLine = 0;
int ledPin = 4;
int backButton = 2;
bool isMain;
bool isSub;
int fadeLevel = 5;
void setup ()
  lcd.clear();
  lcd.begin(16, 2);
  delay(2000);
  print_menu();
  isMain = true;
  isSub = false;
} //end of setup
void loop ()
  if(isMain == true && isSub == false){
      selection_stuff(MenuItems);
    }else if (isMain == false && isSub == true){
      selection_stuff(SubMenuItems);
} //End loop()
void selection_stuff(int currentList){
  if (result) {
      CursorLine = 0; // roll over to last item
    else if (CursorLine > currentList - 1) {
      CursorLine = currentList - 1;                 // roll over to first item
    printManager();
  } // End if result
    lcd.clear();
    selectManager();
void printManager(){
      print_menu();
      print_submenu();
void selectManager(){
      selection();
      submenu_selection();
void print_menu()
  lcd.clear();
  lcd.print("   Main Menu  ");
  lcd.print("<"); lcd.setCursor(columnsLCD - 1, 1); lcd.print(">");
  lcd.print(MenuItems[CursorLine]);
void print_submenu()
  lcd.clear();
  lcd.print("   2nd Menu  ");
  lcd.print(SubMenuItems[CursorLine]);
void selection()
    case 0:
      isMain = false;
      isSub = true;
    case 1:
    case 2:
      lcd.print("                     ");
      print_menu();
    case 3:
    case 4:
      delay(3000);
      print_menu();
    case 5:
      lcd.print("                    ");
      delay(2000);
      resetfunc();
  } //end switch
  //delay(2000);
} //End selection
void submenu_selection() {
    case 0:
      //turn on servo 1
    case 1:
      //turn on servo 2
    case 2:
      isMain = true;
      isSub = false;
Any solutions for this? As always, the library I used is included in the original post.
Probably not the problem but, you create three submenu items and then declare that there are only two.
I saw the problem there, but it still fills with garbage memory in all of the menus.
