Hello All,
I want to control 2 motors using a simple joystick connected to an Arduino that will sent a PWM signal to the L298N.
But for some simple reason , I can't compile my sketch, it will return me this error,
'xMap' was not declared in this scope.
I did copy/paste this sketch from a website, assuming that the coding was correct.
Any help appreciated, probably something very basic that I don't understand yet,
Thank You
#define MR1 2 //digital pin for controlling polarity motor1
#define MR2 3 //digital pin for controlling polarity motor1
#define ML1 4 //digital pin for controlling polarity motor2
#define ML2 5 //digital pin for controlling polarity motor2
const int ENA = 9; //PWM pin to control the speed of motor1
const int ENB = 10; //PWM pin to control the speed of motor2
const int SW_pin = 8; //digital pin
const int X_pin = 19; //analog pin
const int Y_pin = 20; //analog pin
pinMode(SW_pin, INPUT);
digitalWrite(SW_pin, HIGH);
pinMode(MR1, OUTPUT);
pinMode(MR2, OUTPUT);
pinMode(ML1, OUTPUT);
pinMode(ML2, OUTPUT);
pinMode (ENA, OUTPUT);
pinMode (ENB, OUTPUT);
Serial.print("Switch: ");
Serial.print(digitalRead(SW_pin));
xMap=analogRead(X_pin);
yMap=analogRead(Y_pin);
xMap1 = map(xMap, 0,1023, 0, 10);
yMap1 = map(yMap,0,1023,0,10);
Serial.print(" | ");
Serial.print("X-axis: ");
Serial.print(xMap1);
Serial.print("Y-axis: ");
Serial.print(yMap1);
Serial.println(" | ");
if(xMap1==5 && ( yMap1==0 || yMap1 <=3))
// forward
digitalWrite(MR1,HIGH);// clockwise rotation of motor1
digitalWrite(MR2,LOW);
digitalWrite(ML1,HIGH);// clockwise rotation of motor2
digitalWrite(ML2,LOW);
analogWrite(ENA, 255);// speed of motor1
analogWrite(ENB, 255);// speed of motor2
else if(xMap1== 5 && (yMap1>=6 || yMap1 == 10))
//backward
digitalWrite(MR1,LOW);
digitalWrite(MR2,HIGH);// anticlockwise rotation of motor1
digitalWrite(ML1,LOW);
digitalWrite(ML2,HIGH);// anticlockwise rotation of motor2
else if((xMap1==0 || yMap1 <=3) && yMap1 ==4)
//left
analogWrite(ENA, 0);
else if((xMap1 == 10) && yMap1 == 4)
// right
analogWrite(ENB, 0);
// stop
