Need help with accelerometer triggering temboo over wifi
Hello,
I've got a sparkfun 345xl accelerometer connected to an Arduino Yun. The accelerometer detects activity, and then uses temboo + twillo to send an SMS message.
I'm also a complete beginner, and have tried to hash code snippets together from what I've found online, without actually knowing much of what I'm doing.
The code below somewhat works, and I can sense and display activity in the serial monitor. A call is made to Temboo and an SMS is sent successfully. However, this only happens the first time activity is detected. Subsequent times, it detects activity, but then doesn't send out the call to temboo.
What am I doing wrong? Could someone kindly help me learn how to do this correctly? Thank you in advance.
N.
#include <Bridge.h>
#include <Temboo.h>
#include "TembooAccount.h" // contains Temboo account information, as described below
#include <SparkFun_ADXL345.h>         // SparkFun ADXL345 Library
/*********** COMMUNICATION SELECTION ***********/
/*    Comment Out The One You Are Not Using    */
//ADXL345 adxl = ADXL345(10);           // USE FOR SPI COMMUNICATION, ADXL345(CS_PIN);
ADXL345 adxl = ADXL345();             // USE FOR I2C COMMUNICATION
int calls = 1;   // Execution count, so this doesn't run forever
int maxCalls = 2;   // Maximum number of times the Choreo should be executed
  // For debugging, wait until the serial console is connected
  delay(4000);
  while(!Serial);
  Bridge.begin();
adxl.powerOn();                     // Power on the ADXL345
  adxl.setRangeSetting(16);           // Give the range settings
                                      // Accepted values are 2g, 4g, 8g or 16g
                                      // Higher Values = Wider Measurement Range
                                      // Lower Values = Greater Sensitivity
  adxl.setSpiBit(0);                  // Configure the device to be in 4 wire SPI mode when set to '0' or 3 wire SPI mode when set to 1
                                      // Default: Set to 1
                                      // SPI pins on the ATMega328: 11, 12 and 13 as reference in SPI Library
  adxl.setActivityXYZ(1, 1, 1);       // Set to activate movement detection in the axes "adxl.setActivityXYZ(X, Y, Z);" (1 == ON, 0 == OFF)
  adxl.setActivityThreshold(75);      // 62.5mg per increment   // Set activity   // Inactivity thresholds (0-255)
  adxl.setInactivityXYZ(1, 1, 1);     // Set to detect inactivity in all the axes "adxl.setInactivityXYZ(X, Y, Z);" (1 == ON, 0 == OFF)
  adxl.setInactivityThreshold(75);    // 62.5mg per increment   // Set inactivity // Inactivity thresholds (0-255)
  adxl.setTimeInactivity(20);         // How many seconds of no activity is inactive?
  adxl.setTapDetectionOnXYZ(0, 0, 0); // Detect taps in the directions turned ON "adxl.setTapDetectionOnX(X, Y, Z);" (1 == ON, 0 == OFF)
  // Set values for what is considered a TAP and what is a DOUBLE TAP (0-255)
  adxl.setTapThreshold(50);           // 62.5 mg per increment
  adxl.setTapDuration(15);            // 625 μs per increment
  adxl.setDoubleTapLatency(80);       // 1.25 ms per increment
  adxl.setDoubleTapWindow(200);       // 1.25 ms per increment
  // Set values for what is considered FREE FALL (0-255)
  adxl.setFreeFallThreshold(7);       // (5 - 9) recommended - 62.5mg per increment
  adxl.setFreeFallDuration(30);       // (20 - 70) recommended - 5ms per increment
  // Setting all interupts to take place on INT1 pin
  //adxl.setImportantInterruptMapping(1, 1, 1, 1, 1);     // Sets "adxl.setEveryInterruptMapping(single tap, double tap, free fall, activity, inactivity);"
                                                        // Accepts only 1 or 2 values for pins INT1 and INT2. This chooses the pin on the ADXL345 to use for Interrupts.
                                                        // This library may have a problem using INT2 pin. Default to INT1 pin.
  // Turn on Interrupts for each mode (1 == ON, 0 == OFF)
  adxl.InactivityINT(1);
  adxl.ActivityINT(1);
  adxl.FreeFallINT(0);
  adxl.doubleTapINT(0);
  adxl.singleTapINT(0);
//attachInterrupt(digitalPinToInterrupt(interruptPin), ADXL_ISR, RISING);   // Attach Interrupt
  // Accelerometer Readings
  int x,y,z;
  adxl.readAccel(&x, &y, &z);         // Read the accelerometer values and store them in variables declared above x,y,z
    byte interrupts = adxl.getInterruptSource();
    if(adxl.triggered(interrupts, ADXL345_ACTIVITY)){
    Serial.println("*** ACTIVITY ***");
     //add code here to do when activity is sensed
  if (calls <= maxCalls) {
    Serial.println("Running SendSMS - Run #" + String(calls++));
    TembooChoreo SendSMSChoreo;
    // Invoke the Temboo client
    SendSMSChoreo.begin();
    // Set Temboo account credentials
    SendSMSChoreo.setAccountName(TEMBOO_ACCOUNT);
    SendSMSChoreo.setAppKeyName(TEMBOO_APP_KEY_NAME);
    SendSMSChoreo.setAppKey(TEMBOO_APP_KEY);
    // Set profile to use for execution
    SendSMSChoreo.setProfile("Twillo");
    // Identify the Choreo to run
    SendSMSChoreo.setChoreo("/Library/Twilio/SMSMessages/SendSMS");
    // Run the Choreo; when results are available, print them to serial
    SendSMSChoreo.run();
    while(SendSMSChoreo.available()) {
      char c = SendSMSChoreo.read();
      Serial.print(c);
    SendSMSChoreo.close();
  Serial.println("Waiting...");
  delay(30000); // wait 30 seconds between SendSMS calls
Given that code, how many times do you expect to send an SMS?
Hi Paul,
Thank you very much for responding. I realise the code i copied is set to stop after 2 runs, and delay by 30 seconds.
However I'd like to send an SMS message when activity is detected, and then stay quiet for a period of time, say 5 minutes, before it is able to detect activity again and send me the next SMS.
So:
  1. Activity is triggered.
  2. Send SMS.
  3. Wait 5 min.
  4. Detect fresh activity whenever it happens next.
  5. Send SMS
Hope that makes sense.
N.
This is what happens now:
  1. Power on.
  2. Activity detected.
  3. SMS message sent successfully.
  4. Another SMS message is sent (I can change that by setting max calls to 1)
  5. Serial monitor goes back to "waiting" and ignores any activity for 30 seconds.
  6. I shake the accelerometer again.
  7. Serial monitor shows "activity"
  8. Serial monitor shows "waiting" without actually sending out the SMS.
I can repeat steps 6-8 over and over (with 30 second intervals in between), but the SMS is only sent the first time. I have to power down the board, and then start over to trigger the first SMS to be sent.
N.
Paul,
Thank you for the hint. I fiddled around some more and managed to get it working by removing the calls and max calls section.
Here's the working code:
#include <Bridge.h>
#include <Temboo.h>
// int calls = 1;   // Execution count, so this doesn't run forever
// int maxCalls = 1;   // Maximum number of times the Choreo should be executed
  delay(4000);
  while(!Serial);
  Bridge.begin();
  int x,y,z;
    //if (calls = 1) {
    Serial.println("Sending SMS");
     // Serial.print(c); if you want to see the actual choreo output
    Serial.print("SMS Success and... ");
  delay(10000); // wait 10 seconds between SendSMS calls
