I’m looking for help creating an Ethernet relay. I purchased a small board with 2 relays, but the web service isn’t available. I see the IP address, but can’t bring it up. I apologize if this post is in the wrong spot. I’ve been banging my head trying to get this up and going. I have a product I’m wanting to create, so any advice would be appreciated. I know zero, absolutely nothing about programming. I am as new as they get. Thank you for allowing me to put this out there. Even pointing me in the direction of the first step would be a great help.
Then be careful not to get in over your head. There is no surer path to failure than to bite off more than you can chew and then think that you are too good to go and learn the simple examples. Start with just a relay. Forget the internet. Get the relay working. Once you have that, then start thinking about the internet. You have to build these things one piece at a time.
You can go to your local computer store and get an ethernet switch for not very much money that will give you as many ports as you want, starting from about 2 to 96 that I am familiar with. Then you can use all the devices as wanted without transfering anything.
