Need help with an "IF" statement ...
Hi all,
I need someone's help for resolving a little problem in one of my IF statements ...
There comes the code :
void WeatherDayControl(){
  // Conditions for ENABLING aeration
  if(ActiveAerationState == 0){
    if((dht_IN_Temp >= Temp_IN_Value + Temp_IN_Value_Threshold && dht_IN_Temp - dht_EXT_Temp >= 5) || dht_IN_Hum - dht_EXT_Hum <= -15 || millis() - ActiveAerationPreviousStateChangeMillis >= ActiveAerationOffDuration){
      ActiveAerationOn();
  // Conditions for DISABLING aeration
  if(ActiveAerationState == 1 && millis() - ActiveAerationPreviousStateChangeMillis >= ActiveAerationOnDuration){
    if((dht_IN_Temp <= Temp_IN_Value - Temp_IN_Value_Threshold && dht_IN_Temp - dht_EXT_Temp <= 2 ) || dht_IN_Hum - dht_EXT_Hum >= 5){
      ActiveAerationOff();
Where "ActiveAerationPreviousStateChangeMillis" corresponds to this :
void ActiveAerationOn(){
    ActiveAerationPreviousStateChangeMillis = millis();
    ActiveAerationState = 1;
  FanOUTon();
  FanINon();
  ServoOUTopen();
  ServoINopen();
void ActiveAerationOff(){
  if(ActiveAerationState == 1){
    ActiveAerationState = 0;
  ServoINclose();
  ServoOUTclose();
  FanINoff();
  FanOUToff();
In fact, it works great except the (dht_IN_Temp >= Temp_IN_Value + Temp_IN_Value_Threshold && dht_IN_Temp - dht_EXT_Temp >= 5) statement which appears not to be executed.
Is there something to do when mixing AND and OR arguments inside an IF statement ?
Thanks !
simkard:
Sometimes the order of execution of operations is not what you might expect. I think it may be doing comparisons before addition. To force it to do what you want, try parenthesis:
((dht_IN_Temp >= (Temp_IN_Value + Temp_IN_Value_Threshold)) && ((dht_IN_Temp - dht_EXT_Temp) >= 5))
Addition has higher order of precedence, so the compiler shouldn't be getting that mixed up (Operators in C and C++ - Wikipedia) - however the brackets are a good idea for clarity anyway.
What type are your variables?
For clarity put only one comparison operator per line! You might then just see the problem.
A line like
Is so confusing I don't think there's a chance it's doing the right thing. And if it is it's totally unmaintainable.
I'd at least try to put the tests on separate lines
 if(	(dht_IN_Temp >= (Temp_IN_Value + Temp_IN_Value_Threshold) &&
		(dht_IN_Temp - dht_EXT_Temp >= 5) ||
		(dht_IN_Hum - dht_EXT_Hum <= -15) ||
		(millis() - ActiveAerationPreviousStateChangeMillis >= ActiveAerationOffDuration)
But it's not clear if is should be
a && (b || c || d)
or
(a && b || c) || d
or whatever. Now I'm sure you could look into the operator precedence but you shouldn't rely on that anyway. I'd be included to split the calculations from the tests
	int a = Temp_IN_Value + Temp_IN_Value_Threshold;
	int diff_temp = dht_IN_Temp - dht_EXT_Temp ;
	int diff_hum = dht_IN_Hum - dht_EXT_Hum ;
	int d = millis() - ActiveAerationPreviousStateChangeMillis ;
   if(dht_IN_Temp >= a && diff_temp >= 5 || diff_hum <= -15 || d >= ActiveAerationOffDuration)	{
This needs better variable names and still needs ()s to force the order of tests but I think it's a lot clearer.
Rob
