I need help with an LCD problem…I am running a 20x2 dot matrix LCD with the Sanyo LC7985NA controller. The unit also has a Seiko chip SED1181FLA. I have the screen powered up and it has (20) solid 5x7 dots only on the top row. I tried using the prewritten LCD codes with no luck.
I tested the pinouts by checking continuity and found all GND’s and +5V. I also found DB0-7, RS, RW, & E.
Please review these photos I posted on Flickr. They give a little information about what is happening…
http://www.flickr.com/photos/37885360@N06/4315321772/
http://www.flickr.com/photos/37885360@N06/4315321564/
My Pinout:
Pin 1 - Metal Casing GND #1
::::Unattached for now (not necessary)
Pin 2 - LED GND (this is a two-colored external LED which I know how to control)
Pin 3 - +5V Green LED
Pin 4 - + 5V Red LED
Pin 5 - DB4
::::Attached to Arduino Pin 5
Pin 6 - DB5
::::Attached to Arduino Pin 4
Pin 7 - DB6
::::Attached to Arduino Pin 3
Pin 8 - DB7
::::Attached to Arduino Pin 2
Pin 9 - E: Execution start input to R/W
::::Attached to Arduino Pin 11
Pin 10 - RS
::::Attached to Arduino Pin 12
Pin 11 - Sanyo V5, Seiko VSSH
::::Attached to GND
Pin 12 - Sanyo VDD, Seiko VDD
::::Attached to +5V
Pin 13 - Sanyo R/W, DB0, DB1, DB2, DB3, Seiko VSS
::::Attached to GND
Pin 14 - Metal Casing GND #2
My Code:
LiquidCrystal Library - setCursor
Demonstrates the use a 16x2 LCD display. The LiquidCrystal
library works with all LCD displays that are compatible with the
Hitachi HD44780 driver. There are many of them out there, and you
can usually tell them by the 16-pin interface.
This sketch prints to all the positions of the LCD using the
setCursor(0 method:
The circuit:
- LCD RS pin to digital pin 12
- LCD Enable pin to digital pin 11
- LCD D4 pin to digital pin 5
- LCD D5 pin to digital pin 4
- LCD D6 pin to digital pin 3
- LCD D7 pin to digital pin 2
Library originally added 18 Apr 2008
by David A. Mellis
library modified 5 Jul 2009
by Limor Fried (http://www.ladyada.net)
example added 9 Jul 2009
by Tom Igoe
modified 22 August 2009
by Tom Igoe
http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
// these constants won’t change. But you can change the size of
// your LCD using them:
const int numRows = 2;
const int numCols = 20;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// set up the LCD’s number of rows and columns:
lcd.begin(numRows, numCols);
// loop from ASCII ‘a’ to ASCII ‘z’:
for (int thisLetter = ‘a’; thisLetter <= ‘z’; thisLetter++) {
// loop over the rows:
for (int thisRow= 0; thisRow < numRows; thisRow++) {
// loop over the columns:
for (int thisCol = 0; thisCol < numCols; thisCol++) {
// set the cursor position:
lcd.setCursor(thisCol,thisRow);
// print the letter:
lcd.print(thisLetter, BYTE);
delay(200);
Any ideas of what could be wrong? It would greatly be appreciated!
