Need help with arduino code, reading 2 ADC values over XBEE
Right now I have 2 ADC signals hooked up to AD0 and AD1 on my first Xbee. I have the second xbee connected to my arduino uno and am trying to read the values using the rx and tx pins. I have code that works perfectly for the first ADC value (analog value on AD0).
float temp;
    if (Serial.available() >= 20)
    if(Serial.read() == 0x7E)
      for (int i = 1; i < 11; i++)
        byte discardByte = Serial.read();
      float analogMSB = Serial.read();
      float analogLSB = Serial.read();
      float analogReading = analogLSB + (analogMSB * 256);
      temp = analogReading / 1023 * 3.32;
      Serial.print("----------------------------------------------------");
      Serial.print('\n');
      Serial.print("Sensor One Reading:");
      Serial.print('\t');
      Serial.print('\n');
      Serial.print(temp);
      Serial.print('\t');
      //Serial.print(SecondSensorVal);
      Serial.print('\n');
Now I also need to get the reading from AD1, but I'm not sure how to do it. If someone could help me out here that would be great.
I figured it out.
New code:
float firstSensVal;
float secondSensVal;
      float firstAnalogMSB = Serial.read();
      float firstAnalogLSB = Serial.read();
      float firstAnalogReading = firstAnalogLSB + (firstAnalogMSB * 256);
      firstSensVal = firstAnalogReading / 1023 * 3.32;
      float secondAnalogMSB = Serial.read();
      float secondAnalogLSB = Serial.read();
      float secondAnalogReading = secondAnalogLSB + (secondAnalogMSB * 256);
      secondSensVal = secondAnalogReading / 1023 * 3.32;
      Serial.print('\n');
      Serial.print('\t');
      Serial.print("Sensor Two Reading:");
      Serial.print('\n');
      Serial.print(firstSensVal);
      Serial.print('\t');Serial.print('\t');Serial.print('\t');
      Serial.print(secondSensVal);
      Serial.print('\n');
Serial.read() does not return a float. The math operation does not create a float. The first two variables should be uint8_t. The third should be int.
When firstAnalogReading becomes an int, the 1023 needs to become 1023.0, to force floating point arithmetic to be used.
