What is the difference between this code:
pinMode(pingLeft, OUTPUT);
digitalWrite(pingLeft, LOW);
delayMicroseconds(2);
digitalWrite(pingLeft, HIGH);
delayMicroseconds(5);
pinMode(pingLeft,INPUT);
durationLeft = pulseIn(pingLeft,HIGH);
and this code:
pinMode(pingRight, OUTPUT);
digitalWrite(pingRight, LOW);
digitalWrite(pingRight, HIGH);
pinMode(pingRight,INPUT);
durationRight = pulseIn(pingRight,HIGH);
The pin number and where the data is stored. This should be moved into a function:
durationLeft = pingTime(pingLeft);
durationRight = pingTime(pingRight);
distanceInchesLeft = microsecondsToInches(durationLeft);
The distanceInchesLeft variable is long. Why? If the truck is more than 65536 inches (5,460 feet), I don't think you are in any danger of hitting it. Even an unsigned int is oversize. Even a signed int can hold a larger value than can be displayed on a 4 digit display.
Have you successfully displayed anything on the displays? There is nothing in your code to indicate that you have.
Here is some code I use to display data on a 4 digit, 7 segment display:
6-13-2011
Spark Fun Electronics 2011
Nathan Seidle
This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
4 digit 7 segment display:
http://www.sparkfun.com/products/9483
Datasheet:
http://www.sparkfun.com/datasheets/Components/LED/7-Segment/YSD-439AR6B-35.pdf
This is an example of how to drive a 7 segment LED display from an ATmega without the use of current limiting resistors.
This technique is very common but requires some knowledge of electronics - you do run the risk of dumping too
much current through the segments and burning out parts of the display. If you use the stock code you should be ok, but
be careful editing the brightness values.
This code should work with all colors (red, blue, yellow, green) but the brightness will vary from one color to the next
because the forward voltage drop of each color is different. This code was written and calibrated for the red color.
This code will work with most Arduinos but you may want to re-route some of the pins.
7 segments
4 digits
1 colon
12 pins required for full control
int digit1 = 11; //PWM Display pin 1
int digit2 = 10; //PWM Display pin 2
int digit3 = 9; //PWM Display pin 6
int digit4 = 6; //PWM Display pin 8
//Pin mapping from Arduino to the ATmega DIP28 if you need it
//http://www.arduino.cc/en/Hacking/PinMapping
int segA = A1; //Display pin 14
int segB = 3; //Display pin 16
int segC = 4; //Display pin 13
int segD = 5; //Display pin 3
int segE = A0; //Display pin 5
int segF = 7; //Display pin 11
int segG = 8; //Display pin 15
#define DIGIT_ON LOW
#define DIGIT_OFF HIGH
#define SEGMENT_ON HIGH
#define SEGMENT_OFF LOW
pinMode(segA, OUTPUT);
pinMode(segB, OUTPUT);
pinMode(segC, OUTPUT);
pinMode(segD, OUTPUT);
pinMode(segE, OUTPUT);
pinMode(segF, OUTPUT);
pinMode(segG, OUTPUT);
pinMode(digit1, OUTPUT);
pinMode(digit2, OUTPUT);
pinMode(digit3, OUTPUT);
pinMode(digit4, OUTPUT);
pinMode(13, OUTPUT);
Serial.begin(57600);
for(int i=0; i<10000; i++)
displayNumber(i);
//Display brightness
//Each digit is on for a certain amount of microseconds
//Then it is off until we have reached a total of 20ms for the function call
//Let's assume each digit is on for 1000us
//If each digit is on for 1ms, there are 4 digits, so the display is off for 16ms.
//That's a ratio of 1ms to 16ms or 6.25% on time (PWM).
//Let's define a variable called brightness that varies from:
//5000 blindingly bright (15.7mA current draw per digit)
//2000 shockingly bright (11.4mA current draw per digit)
//1000 pretty bright (5.9mA)
//500 normal (3mA)
//200 dim but readable (1.4mA)
//50 dim but readable (0.56mA)
//5 dim but readable (0.31mA)
//1 dim but readable in dark (0.28mA)
#define DISPLAY_BRIGHTNESS 500
void displayNumber(int toDisplay)
long beginTime = millis();
for(int digit = 4 ; digit > 0 ; digit--)
//Turn on a digit for a short amount of time
switch(digit)
case 1:
analogWrite(digit1, DIGIT_ON);
case 2:
digitalWrite(digit2, DIGIT_ON);
case 3:
digitalWrite(digit3, DIGIT_ON);
case 4:
digitalWrite(digit4, DIGIT_ON);
//Turn on the right segments for this digit
lightNumber(toDisplay % 10);
toDisplay /= 10;
delayMicroseconds(DISPLAY_BRIGHTNESS); //Display this digit for a fraction of a second (between 1us and 5000us, 500 is pretty good)
//Turn off all segments
lightNumber(10);
//Turn off all digits
digitalWrite(digit1, DIGIT_OFF);
digitalWrite(digit2, DIGIT_OFF);
digitalWrite(digit3, DIGIT_OFF);
digitalWrite(digit4, DIGIT_OFF);
while((millis() - beginTime) < 10); //Wait for 20ms to pass before we paint the display again
//Given a number, turns on those segments
//If number == 10, then turn off number
void lightNumber(int numberToDisplay)
switch (numberToDisplay){
case 0:
digitalWrite(segA, SEGMENT_ON);
digitalWrite(segB, SEGMENT_ON);
digitalWrite(segC, SEGMENT_ON);
digitalWrite(segD, SEGMENT_ON);
digitalWrite(segE, SEGMENT_ON);
digitalWrite(segF, SEGMENT_ON);
digitalWrite(segG, SEGMENT_OFF);
case 1:
digitalWrite(segA, SEGMENT_OFF);
digitalWrite(segD, SEGMENT_OFF);
digitalWrite(segE, SEGMENT_OFF);
digitalWrite(segF, SEGMENT_OFF);
case 2:
digitalWrite(segC, SEGMENT_OFF);
digitalWrite(segG, SEGMENT_ON);
case 3:
case 4:
case 5:
digitalWrite(segB, SEGMENT_OFF);
case 6:
case 7:
case 8:
case 9:
case 10:
The displays use up a lot of pins. Unless you have a Mega, you will run out of pins trying to connect two of them.
