I am working on a bike turn signal/brake signal/horn project. I currently have my code running so that I have to hold a button for the turn signal to keep flashing, however would like it to work so that one click turns on the signal and another turns it off.
I have no idea how to even begin coding this. Any help would be appreciated.
Thanks in advance
(If you want to see my current code, i'll put it right here:
int L=2; //Varible used to store the digitalRead result for the left turn
int R = 2; // Varible used to store the digitalRead result for the right turn
{pinMode(2,INPUT); // Pin that the left button is connected to
pinMode(3,INPUT); // Right button
pinMode(13,OUTPUT); // Left LED Pin
pinMode(12,OUTPUT);
L=digitalRead(2);
R=digitalRead(3);
if(L==0)
{digitalWrite(13,HIGH);// Blinking Sequence
delay(400);
digitalWrite(13,LOW);
delay(400);}
else if (R==0)
{digitalWrite(12,HIGH); // Blinking Sequence
delay(400);
digitalWrite(12,LOW);
delay(400);}
I won't attempt to write the code for you but you'll need another variable (or two), plus an "and" statement (&&).
That variable needs to "remember" if the signal is on or not. Then the logic is: If the button is pushed AND the signal is on, turn it off. If the button is pushed AND the signal is off, turn it on.
Note that you can't read a momentary button during the delay() so you'll probably want to to re-write your code using [u]millis()[/u].
If you take-out the existing delay() statements, you'll need to [u]debounce[/u]. If you don't debounce one button-push will be read as several button pushes an you'll get "random" results.
DVDdoug:
Ok I have 3 questions:
How would one go about de-bouncing a button?
The delays are there for the light to flash. How would I use the millis() command to achieve the same result
Can this variable be a Boolean? And if so, how would one go about toggling the Boolean with a command?
I'll try to implement the changes and see if it works, but would still like to have those questions answered
The answers can be found in the first five sketches in IDE → file/examples/digital. A grasp of the concepts/techniques presented there will open up many possibilities.
Thank you all for your help. I ended up using a library called “Button.h” by Michael Adams (https://github.com/madleech/ButtonL) and used the code from one of the digital examples (Blink without delay). It worked.
I appreciate all of your help.
If you want to see my working code, here it is:
#include <Button.h>
int ledButtonLeft = LOW;
int ledStateLeft = LOW;
int ledStateRight = LOW;
int ledButtonRight = LOW;
unsigned long previousMillis = 0;
const long interval = 400;
Button LeftTrn(2);
Button RightTrn(3);
{LeftTrn.begin();
RightTrn.begin();
pinMode(12,OUTPUT);
if (LeftTrn.pressed())
{ if (ledButtonLeft == LOW) {
ledButtonLeft = HIGH;
} else
if (RightTrn.pressed())
{ if (ledButtonRight == LOW) {
ledButtonRight = HIGH;
} else
if (ledButtonLeft == HIGH){
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledStateLeft == LOW) {
ledStateLeft = HIGH;
ledStateLeft = LOW;
digitalWrite(13, ledStateLeft);
else{
if (ledButtonRight == HIGH){
if (ledStateRight == LOW) {
ledStateRight = HIGH;
digitalWrite(12, ledStateRight);
/*else if (R==0)
delay(400);
delay(400);}
