Need help with BLE server structure
i have recently entered the world of embedded engineering due to work stuff and am still quite new to this world and c++. in one of the projects, i have to create a ble server that a mobile app will connect to show some data to user and set some configs.
i am using esp32-devkit-doit-v1 with arduino framework and platformio.
current architecture:
i have 2 characteristics (i call them channels. easy to say. will continue to call them channels). one for routing and one for data read/ write. the pages i separated into 4 main categories live, list, config and button.
live pages: only written by machine. data is set inside a loop with a certain delay. client can only read.
list pages: it is partially written. there needs to be pagination when displaying data and so the pagination details are written and esp replies with an arr field that has the list of data.
config pages: these pages are fully written by client.
button pages: initially set to 0. when a button is clicked on app, it is set to 1. esp does its thing and sets it back to 0.
the whole thing is wrapped inside a class:
class BleClient {
private:
    BLEServer* server = NULL;
    BLECharacteristic* pageChannel;
    BLECharacteristic* dataChannel;
    // to advertise again after disconnect
    class ServerCallbacks;
    class PageChannelCallbacks;
    class DataChannelCallbacks;
    PAGE currentPage;
    void setCurrentPage(std::string magicString);
    String getDashboardData();
    String getSystemConfig();
    bool setSystemConfig(JsonDocument doc);
    String getCloudConfig();
    bool setCloudConfig(JsonDocument doc);
    String getListSensor();
    String getListSensor(JsonDocument doc);
    String getInitialButtonState();
    bool calibrate();
public:
    void init();
    void loop();
and here are the pages. the methods will make more sense after you see the pages:
enum PAGE {
    DEFAULT_PAGE,
    DASHBOARD,
    CONFIG_SYSTEM,
    CONFIG_CLOUD,
    LIST_SENSOR,
    BUTTON_CALIBRATION,
// default
// does nothing. but we had to start somewhere
#define DEFAULT_ROUTE "/"
// live
#define DASHBOARD_ROUTE "/live/dashboard"
// config
#define CONFIG_SYSTEM_ROUTE "/config/system"
#define CONFIG_CLOUD_ROUTE "/config/cloud"
// list
#define LIST_SENSOR_ROUTE "/list/sensor"
// button
#define BUTTON_CALIBRATION_ROUTE "/button/calibration"
the problem:
route changing is slow and doing it too fast can mess things up, since data of all pages are write on the same channel. separating the channels would be great but these callbacks seem to eat up a lot of spaces, my last benchmarking showed that this class was eating 900kb of flash memory.
my question:
have you worked with BLE? is there a better way to handle a BLE server? is there a "common practice" that i am not aware of? do you see anything wrong in my approach?
any and all criticisms, suggestions, helps are appreciated.
if any questions, feel free to ask. if need more context, ill provide that too.
thank you.
I would start with a BLE library example.
