Need Help With Button
Hello, I am new to working with the Arduino, and I am having trouble with coding. What I'm trying to do is make a button that you hold and when you let go after holding for at least 10 seconds, it moves on to the main part of the code. I was thinking of using a while statement, but I'm not sure. Thanks!
Welcome to the forum heyitskarl121.
Please describe what this is for. Show us what code you have so far.
heyitskarl121:
Hello, I am new to working with the Arduino, and I am having trouble with coding. What I’m trying to do is make a button that you hold and when you let go after holding for at least 10 seconds, it moves on to the main part of the code. I was thinking of using a while statement, but I’m not sure. Thanks!
try something like this …
unsigned int startTime;
unsigned int heldTime;
int buttonState;
// Connect your button to a Pin and to GND
// I selected Pin #8
// Change the value below to the pin YOU used
#define myButton 8
Setup()
    // Internal Resistor will Pull-Up High when button is released
    pinMode( myButton, INPUT_PULLUP );
    // Reset the 10 second timer
    startTime = millis();
    heldTime = startTime;
    // Wait here until the Button is held for 10 consecutive seconds
    while ( heldTime - startTime < 10000 )
        // Read the current state of the Button Input
        buttonState = digitalRead( myButton );
        // Did they release button too early?
        if ( buttonState == HIGH )
            // Sorry, we have to reset the 10 second timer
        // Are they still holding the button down?
            // Then keep updating the Hold Down timer
            heldTime = millis();
     // SUCCESS !
     // The Button was Held down for 10 consecutive seconds
     // Now we can advance to the Main Program, the Loop()
Loop ()
    // Do fun stuff here
Oops! "setup()" and "loop()" should not have capital letters. Typing on an iPad?
Also you need "void" ;)
void setup() { . . . }
void loop() { . . . }
