I need some help with my code for my LED (Neopixel) lamp.
It has one capacitive touch button, wich should turn the Neopixels on/off, if taped ones and change the brightness if you hold him. I'm kinda new, it's the first time using "millis" for me.
I added serial debugoutput to your code that makes visible what is happening inside the code.
it uses a macro for this. macros are no C++-functions. They are pre-compile-"functions"
So run this code to analyse what you code is doing right know what is missing an dmust be added
#include <CapacitiveSensor.h>
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 10
//#define debugTxtVar(abc, def) Serial.print("< "#abc" = "); Serial.print(def); Serial.println('>')
// using the #define "statement" to make the compiler "write" code
// #define can be used to make the compiler replace text that describes something with (almost) anything else
// easy example
// let's assume IO-pin number 4 shall be set to work as output
// the command for defining an IO-pin to be configured as output is
// pinMode(4,OUTPUT);
// the number "4" says nothing about he purpose of this IO-pin
// let's assume the IO-pin shall switch On/Off a buzzer
// you would have to add a comment to explain
// pinMode(4,OUTPUT); // IO-pin 4 is buzzer
// the compiler needs the number. To make the code easier to read and understand
// #define BuzzerPin 4
// So the command looks like this
// pinMode(BuzzerPin,OUTPUT);
// the descriptive word "BuzzerPin" gets replaced through the compiler by a "4"
// so what the compiler compiles is still 'pinMode(4,OUTPUT);'
// the #define can do much more than just replace a word by a single number
// it can even take parameters like in this example
#define debugTxtVar(myParameterText, variableName) \
Serial.print(#myParameterText " " #variableName"="); \
Serial.println(variableName);
Adafruit_NeoPixel strip = Adafruit_NeoPixel(4, PIN, NEO_GRB + NEO_KHZ800);
CapacitiveSensor cs_4_2 = CapacitiveSensor(2, 4);
int long_tap = false;
int short_tap = false;
unsigned long previousMillis = 0;
const long interval = 1000;
cs_4_2.set_CS_AutocaL_Millis(0xFFFFFFFF);
strip.begin();
strip.show();
delay(200); // remove this delay for final use
// it is just inserted to reduce the speed of the serial-output
long sensor1 = cs_4_2.capacitiveSensor(30);
if (sensor1 > 1000) {
debugTxtVar("sensor1 > 1000)",sensor1);
if (currentMillis - previousMillis >= interval) {
debugTxtVar("interval is over",long_tap);
if (long_tap == true) {
strip.setPixelColor(0, 255, 255, 255);
else {
short_tap = false;
debugTxtVar("long_tap is false",long_tap);
debugTxtVar("long_tap is false",short_tap);
