Need help with changing code.
Can someone help me convert some code over to a different shield? I'm new to this and cant find the part of the code that sets the pins. The reason I want to do this is because I found shields for a touchscreen LCD cheaper on ebay and adafruit then on seedstudio. I do not currently own any shields.
The project I want to build is the ArduinoPhone
Any help is great!
Get your cheap shield, run some sample code. If it works, come ask later.
Do you think someone will work FOR you even before YOU put some real time and money in getting the hardware? This is a volunteer forum. You show you have done your part: get the hardware and run basic test and attempt to make some code conversion, then someone else will do their part to help you.
