Hello guys
im new in arduino and i am trying to make some projects.
i use this tut :: ESP8266 Android App To Control Arduino Digital Pins and Toggle LEDs
now i want to use ESP8266 library for Arduino : GitHub - itead/ITEADLIB_Arduino_WeeESP8266: An easy-to-use Arduino ESP8266 library besed on AT firmware.
is there anyone can help me to change the normal code to codes using library?
i go this far
#include <doxygen.h>
#include "ESP8266.h"
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //moshakhas kardane pin haye LCD
SoftwareSerial mySerial(7, 8); // moshakhas kardane pin haye wifi
ESP8266 wifi(mySerial);
#define SSID "Arsalan Wifi" //UserName wifi
#define PASSWORD "arsalan123" //Password wifi
lcd.begin(20, 4);
pinMode(13,OUTPUT);
digitalWrite(13,HIGH);
String IP;
Serial.print("setup begin\r\n");
lcd.print("Connecting to Wifi");
delay(3000);
Serial.print("FW Version: ");
// Serial.println(wifi.getVersion().c_str());
if (wifi.setOprToStation()) {
Serial.print("to station ok\r\n");
Serial.print("to station err\r\n");
if (wifi.joinAP(SSID, PASSWORD)) {
Serial.print("Join AP success\r\n");
Serial.print("IP: ");
Serial.println(wifi.getLocalIP().c_str());
IP = wifi.getLocalIP().c_str();
lcd.setCursor(0, 1);
lcd.print("Join AP success");
lcd.setCursor(0, 2);
lcd.print("IP: "+IP);
Serial.print("Join AP failure\r\n");
lcd.print("Join AP failure");
lcd.print("Contact Administrator");
if (wifi.enableMUX()) {
Serial.print("multiple ok\r\n");
Serial.print("multiple err\r\n");
if (wifi.startTCPServer(80)) {
Serial.print("start tcp server ok\r\n");
lcd.setCursor(0, 3);
lcd.print("Server Ready");
Serial.print("start tcp server err\r\n");
lcd.print("Server Setup Fail");
if (wifi.setTCPServerTimeout(10)) {
Serial.print("set tcp server timout 10 seconds\r\n");
Serial.print("set tcp server timout err\r\n");
Serial.print("setup end\r\n");
but i dont know how to change this part.
if(esp8266.available()) // check if the esp is sending a message
if(esp8266.find("+IPD,"))
delay(1000); // wait for the serial buffer to fill up (read all the serial data)
// get the connection id so that we can then disconnect
int connectionId = esp8266.read()-48; // subtract 48 because the read() function returns
// the ASCII decimal value and 0 (the first decimal number) starts at 48
esp8266.find("pin="); // advance cursor to "pin="
int pinNumber = (esp8266.read()-48); // get first number i.e. if the pin 13 then the 1st number is 1
int secondNumber = (esp8266.read()-48);
if(secondNumber>=0 && secondNumber<=9)
pinNumber*=10;
pinNumber +=secondNumber; // get second number, i.e. if the pin number is 13 then the 2nd number is 3, then add to the first number
digitalWrite(pinNumber, !digitalRead(pinNumber)); // toggle pin
// build string that is send back to device that is requesting pin toggle
String content;
content = "Pin ";
content += pinNumber;
content += " is ";
if(digitalRead(pinNumber))
content += "ON";
content += "OFF";
sendHTTPResponse(connectionId,content);
// make close command
String closeCommand = "AT+CIPCLOSE=";
closeCommand+=connectionId; // append connection id
closeCommand+="\r\n";
sendCommand(closeCommand,1000,DEBUG); // close connection
* Name: sendData
* Description: Function used to send data to ESP8266.
* Params: command - the data/command to send; timeout - the time to wait for a response; debug - print to Serial window?(true = yes, false = no)
* Returns: The response from the esp8266 (if there is a reponse)
String sendData(String command, const int timeout, boolean debug)
String response = "";
int dataSize = command.length();
char data[dataSize];
command.toCharArray(data,dataSize);
esp8266.write(data,dataSize); // send the read character to the esp8266
if(debug)
Serial.println("\r\n====== HTTP Response From Arduino ======");
Serial.write(data,dataSize);
Serial.println("\r\n========================================");
long int time = millis();
while( (time+timeout) > millis())
while(esp8266.available())
// The esp has data so display its output to the serial window
char c = esp8266.read(); // read the next character.
response+=c;
if(debug)
Serial.print(response);
return response;
* Name: sendHTTPResponse
* Description: Function that sends HTTP 200, HTML UTF-8 response
void sendHTTPResponse(int connectionId, String content)
// build HTTP response
String httpResponse;
String httpHeader;
// HTTP Header
httpHeader = "HTTP/1.1 200 OK\r\nContent-Type: text/html; charset=UTF-8\r\n";
httpHeader += "Content-Length: ";
httpHeader += content.length();
httpHeader += "\r\n";
httpHeader +="Connection: close\r\n\r\n";
httpResponse = httpHeader + content + " "; // There is a bug in this code: the last character of "content" is not sent, I cheated by adding this extra space
sendCIPData(connectionId,httpResponse);
* Name: sendCIPDATA
* Description: sends a CIPSEND=<connectionId>,<data> command
void sendCIPData(int connectionId, String data)
String cipSend = "AT+CIPSEND=";
cipSend += connectionId;
cipSend += ",";
cipSend +=data.length();
cipSend +="\r\n";
sendCommand(cipSend,1000,DEBUG);
sendData(data,1000,DEBUG);
* Name: sendCommand
String sendCommand(String command, const int timeout, boolean debug)
esp8266.print(command); // send the read character to the esp8266
response+=c;
if(debug)
return response;
sorry for my bad english,
anyone can help me please?
