Need help with charlieplexing and arrays.
I'm not sure if this is the right place to post this, I hope it is, if not, I'm sorry. I'm using three charlieplexed circuits on a single board (Arduino UNO clone). One uses four pins, the other uses five pins and the last one uses two, respectively. I've tried tutorials on arrays but so far I've failed, I'm looking to get all the circuits in one Array and be able to address them individually, if anyone can help me or point me to the right direction to get started,I'd be very grateful. Charlieplex1 uses pins 13, 12,11. Charlieplex2 uses pins 10 and 9, and Charlieplex3 uses pins 8, 7, 6, 5 and 4. Thanks.
I don't get a clear picture of what you're trying to accomplish. What kind of objects are the elements of the array that you hope to generate? What do you intend to do with them?
You might want to post code for the attempt that makes you most hopeful. That may give us a clearer picture of what you're doing that the clearest verbal description.
I think a diagram might be in order. And a better description of the problem ;)
