Need help with cod on math game
#include <IRremote.h>
#include <IRremoteInt.h>// amount of the class that manages the receiver ir
#include <LiquidCrystal.h>// amount of the class that handles the display
LiquidCrystal LCD (12, 11, 5, 4, 3, 2); // create an object of Liquid Crystal class
Irpin int = 9; // Check the pin 13 to the infrared receiver
IRrecv irrecv (Irpin); // create an object of class IRrecv
decode_results results; // create an object to store the signals received by the receiver
const int contrastoPin = A0; // imposed a pin that will adjust the contrast.
mosfetGate const int = 13; // imposed a pin that will handle the voltage on the mosfet gate
piezoHigh const int = 10; // imposed pin which will sound the piezo with high notes
const int piezoLow = 6; // imposed pin which will sound the piezo with low notes
const int greenLED = 7; // imposed a pin that will handle the green led
const int RedLED = 8; // imposed a pin that will manage the red led
PowerSwitch int = 0; // create a "switch" variable that turns on / off the game
int m = 0; // variable that will host the first operand
int n = 0; // variable that will host the second operand
int answer = 0; // variable that will host the user's response
rispostaEsatta int = 0; // imposed a variable to contain the correct answer to questions
operation int = 0; // variable that contains the value associated with each task
difficulty int = 0; // variable that will host the difficulty User
contrast int = 15; // choose the contrast value.
int score = 0; // variable that holds the player's score
void setup ()
pinMode (contrastoPin, OUTPUT);
pinMode (mosfetGate, OUTPUT);
pinMode (greenLED, OUTPUT);
pinMode (RedLED, OUTPUT);
pinMode (piezoHigh, OUTPUT);
analogWrite (contrastoPin, contrast);
digitalWrite (mosfetGate , HIGH);
digitalWrite (RedLED, HIGH);
digitalWrite (greenLED, HIGH);
delay (1000);
digitalWrite (mosfetGate, LOW);
digitalWrite (RedLED, LOW);
digitalWrite (greenLED, LOW);
irrecv.enableIRIn (); // Start the receiver
lcd.begin (16, 2); // Start the display giving the size (2 lines, 16 characters)
randomSeed (analogRead (3));
Serial.begin (9600);
void loop ()
if (PowerSwitch == 0) {
if (irrecv.decode (& results)) {
if (results.value == 16753245) {
Serial.println (results.value);
PowerSwitch = 1;
digitalWrite (mosfetGate, HIGH);
lcd.print ( "Welcome");
lcd.setCursor (0, 1);
lcd.print ( "math game");
delay (2000);
lcd.clear ();
lcd.setCursor (0, 0);
lcd.print ( "Set");
lcd.setCursor (0.1);
lcd.print ( "Difficulty' 1-5 ");
irrecv.resume (); // wait for the next value entered
while (results.value == 16753245) {
switch (results.value) {
16753245 houses: PowerSwitch = 0;
results.value = 0;
lcd.clear ();
lcd.setCursor (0,0);
lcd.print ( "Goodbye");
lcd.print ( "by Zamein");
delay (3000);
lcd.clear () ;
irrecv.resume ();
16,724,175 homes: difficulty = 1;
lcd.clear ();
lcd.print ( 'Difficulty');
lcd.print (difficulty);
delay (1000);
16,718,055 homes: difficulty = 2;
lcd.clear ();
lcd.print ( " Difficulty: ");
delay (1000);
16,743,045 homes: difficulty = 3;
lcd.clear ();
delay (1000);
16,716,015 homes: difficulty = 4;
lcd.clear ();
lcd.setCursor ( 0, 0);
delay (1000);
16,726,215 homes: difficulty = 5;
lcd.clear () ;
delay (1000);
default: results.value = 16753245 ;
delay (10);
Else {
irrecv.resume (); // put listening the sensor
switch (difficulty) {
case 1: m = random (1, 10);
n = random (1, 10);
action = random (0,2);
case 2: m = random (1, 25);
n = random (1, 25);
case 3: m = random (1, 50);
n = random (1, 50);
action = random (0.2);
case 4: m = random (1, 100);
n = random (1, 100);
case 5: m = random (1, 150 );
n = random (1, 150);
lcd.clear ();
if (action == 0) {
lcd.print ( m);
lcd.print ( "+");
lcd.print (n);
lcd.print ( "=?");
else {
lcd.print (m);
lcd.print ( "*");
lcd. print (n);
lcd.print ( "=?");
while (results.value! = 16,769,565) {
results.value = 16769565;
score = 0;
lcd.clear ();
lcd. setCursor (0.1);
delay (3000);
lcd.clear ();
irrecv.resume ();
16,736,925 homes: answer = 0;
lcd.setCursor (0.1 );
lcd.print ( "");
16,738,455 homes: response response = * 10;
if (answer> 0) {
lcd.print ( "0");
case 16724175: response response = * 10;
answer = answer + 1;
lcd.print ( "1");
16,718,055 homes: response = response * 10;
answer = answer + 2;
lcd.print ( "2");
break ;
16743045 houses: response response = * 10;
response = response + 3;
lcd.print ( "3");
16,716,015 homes: response response = * 10;
response = response + 4;
lcd.print ( "4") ;
case 16726215: response response = * 10;
answer = answer + 5;
lcd.print ( "5");
16,734,885 homes: response response = * 10;
answer = answer + 6;
lcd.print ( "6 ");
case 16728765: response response = * 10;
answer = answer + 7;
lcd.print (" 7 ");
16,730,805 homes: response response = * 10;
response = response + 8;
lcd.print ( "8");
16,732,845 homes: response response = * 10;
answer = answer + 9;
lcd.print ( "9"); ;
Break;
irrecv.resume ();
if (PowerSwitch! = 0) {
if (action == 0) {
rispostaEsatta = m + n;
else {
rispostaEsatta = m * n;
lcd.clear ();
if (response == rispostaEsatta) {
lcd.print ( "Correct answer");
score = score + (10 * difficulty);
lcd.print (score);
lcd.print ( "points");
analogWrite (piezoLow, 500);
delay (250);
analogWrite (piezoLow, 200);
else {
lcd.print ( "wrong answer");
score = 0;
lcd.print (score);
analogWrite (piezoLow, 250);
delay (250);
analogWrite (piezoHigh, 250);
delay (500);
digitalWrite (piezoHigh, LOW);
digitalWrite (piezoLow, LOW);
lcd.clear ( );
results.value = 0;
answer = 0;
And i'm getting a lot of errors.
piz help thx you
FYI I do not take credit for this project.
If you don't take responsibility for the project, what is your part in it?
BTW, cod, I like halibut.
i got the project off line and i'm modifying it for a school project. and i mean code.
That code is garbage and has no chance of compiling.
Where on the internet did you download it? Do you have a link?
Things like this are the reason it could never work:-
    Else
Welcome to the forum.
What is your electronics, programming, arduino, hardware experience?
Do you have all the libraries that the sketch needs?
What is it supposed to do?
What do you want it to do?
What model arduino are you using?
What version IDE are you using?
Tom.... :slight_smile:
http://www.simonesilini.eu/?p=184
This is ware i got the code. I'm using a Arduino Uno just started using about a month to go.
Do you have the three libraries installed?
Yes I believe I do. But just to make sure what libraries do I need?
Nate2177:
You don't need all three libraries. "IRremoteInt.h" is automatically included by the "IRremote.h" header file.
You need "IRremote" and "LiquidCrystal". "LiquidCrystal" is included with the IDE, but you need to separately install "IRremote".
I don't know exactly where you downloaded the copy of the code that you posted, I couldn't find it.
I've attached the version I found, but I still had to add the library includes at the top. They were omitted.
This version compiles OK for me. (Too large to post, so I had to attach it.)
MathGame.ino (11.5 KB)
