Need help with code for a robot
Hello there, I am a newbie for adruino programming. I am attempting to do a simple robot that has an arm that moves from 0 to 180 degrees.with an Arduino UNO. The thing is that I want to add an on/off switch for the robot. The button I have is a simple push button (like the one in the reset button). My code doesn’t seem to work as the robot only moves a few angles with just one press of the button and stops instead of running the program until I press the button again. Could anyone help me please? Here is my code, thank you.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int pos = 0;    // variable to store the servo position
const int buttonPin = 2;     // the number of the pushbutton pin
// variables will change:
int buttonState;         // variable for reading the pushbutton status
boolean check = 0; //while check is 1 the robot arm should move, determines the on/off
myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH)
  check= !check;
  buttonState = 0;
  if (check == 1)
        for(pos = 0; pos < 180; pos+= 1)  // goes from 0 degrees to 180 degrees
          myservo.write(pos);              // tell servo to go to position in variable 'pos'
          delay(10);                       // waits 15ms for the servo to reach the position
        for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
EDIT: If it helps, the button is connected on the 5v Power like in this diagram: http://arduino.cc/en/uploads/Tutorial/button_schem.png
while the servo motor is connected like this : http://ninad243.weebly.com/uploads/1/2/5/5/12557204/1839348_orig.png
How is the servo powered? How is your switch wired?
groundfungus: How is the servo powered? How is your switch wired?
Well for the wiring of the button I used this: http://arduino.cc/en/uploads/Tutorial/button_schem.png and added this one for the servo motor: http://ninad243.weebly.com/uploads/1/2/5/5/12557204/1839348_orig.png
For the power, I am currently using the USB connection to power the card and the servo.
Powering the servo from the Arduino (USB) can cause problems. Try powering the servo from an external (like 4AA batteries). Servos can draw enough current to cause a dip in the power to the Arduino to reset it (and then it will wait for a new button press).
I think your problem is here
  check= !check;
  buttonState = 0;
if (check == 1)
you declared button state to be an integer but in the if statement you are checking to see if its high or low when it can only be a number. Also you have check= !check; which to me doesnt make sense, you should have it as check = false; or check = !true;. You should stick to just true and false for boolean variables, because right now you have buttonState as high and 0. Your for loops are fine. Work on your code grammar and it should work fine
Hope this helps
Psst. HIGH and LOW are numbers. 1 and 0 to be exact.
Also you have ... which to me doesnt make sense,
That's just you, then, It makes perfect sense to the compiler, and is perfectly reasonable.
