Need help with code for button state over RF for my RC car project
Hey guys,
I am working on my first radio controlled car. I am using code I found on istructables.com to control it. It uses 5 buttons (2 for left forward/reverse, 2 for right forward/reverse, and 1 to stop motors). Everything works fine but when I press the button to make left or right go forward(or reverse), the motors keep going until I press the stop button. What I want is for the motors to move ONLY when I have a button pressed. They should stop when I release the button. Below is the code. I would also like to simplify the code if possible. Any help would be much appreciated. Also I could use some help on replacing the buttons with joystick modules. Thanks for your time.
TX Code:
// TRANSMITTER CODE
//NOTE :- THIS TRANSMITTER CODE IS USED WHEN YOU WANT TO CONTROL THE ROBOT VIA THE BREADBOARD REMOTE
#include <VirtualWire.h>
//Assigning controller buttons to Digital Pins
int forward = 8;
int backward = 9;
int rightTurn = 10;
int leftTurn = 11;
int stopMotor = 12;
int remotePins[]= {8,9,10,11,12};//array to store pin nos
    Serial.begin(9600);    // Debugging only
    Serial.println("setup");
    // Initialise the IO and ISR
    vw_setup(2000);  // Bits per sec
    vw_set_tx_pin(3); //Transmitter Data Pin to Digital Pin 3
    for(int i = 0; i<6 ; i++)
      pinMode(remotePins[i], INPUT);
      digitalWrite(remotePins[i],HIGH);
      This is what the loop above does :-
        pinMode(8, INPUT);
        pinMode(9, INPUT);
        pinMode(10, INPUT);
        pinMode(11, INPUT);
        pinMode(12, INPUT);
        digitalWrite(8, HIGH);
        digitalWrite(9, HIGH);
        digitalWrite(10, HIGH);
        digitalWrite(11, HIGH);
        digitalWrite(12, HIGH);*/
}//close setup
  char *msg2;
  if(digitalRead(forward) == LOW)//if the forward button is pressed
    char *msg2 = "1";//send 1 to the receiver
    digitalWrite(13, true); // Flash a light to show transmitting
    vw_send((uint8_t *)msg2, strlen(msg2));//send the byte to the receiver
    vw_wait_tx(); // Wait until the whole message is gone
    digitalWrite(13, false);
  if(digitalRead(backward) == LOW)//if the back button is pressed
    char *msg2 = "2";///send 2 to the receiver
  if(digitalRead(leftTurn) == LOW)//if the left button is pressed
    char *msg2 = "3";//send 3 to the receiver
  if(digitalRead(rightTurn) == LOW)//if the right button is pressed
    char *msg2 = "4";//send 4 to the receiver
    vw_send((uint8_t *)msg2, strlen(msg2));//send the message to the receiver
  if(digitalRead(stopMotor)==LOW)//if the stop button is pressed
   char *msg2 = "5";//send 5 to the receiver
}//close loop
 // End Of Code
RX Code:
// RECIEVER CODE
//NOTE :- THIS CODE IS USED WHEN CONTROLLING THE ROBOT VIA THE BREADBORD REMOTE
//declaring pin nos to FIRST L293D
int en1 = 5;
 int en2 = 6;
 int in1 = 7;
 int in2 = 8;
 int in3 = 9;
 int in4 = 10;
 //declaring pin nos to SECOND L293D
 int en1o2 = 3;
 int en2o2 = 11;
 int in1o2 = 4;
 int in2o2 = 12;
 int in3o2 = 14;
 int in4o2 = 15;
 int motorPin[] = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 14, 15};//array for storing pin nos
    vw_set_rx_pin(2);    //Rx Data pin to Digital  Pin 2
    vw_rx_start();       // Start the receiver PLL running
    for (int i = 0; i < 12; i++)
          pinMode(motorPin[i], OUTPUT);
This is basically what the above for loop does :-
pinMode(en1, OUTPUT);
pinMode(en2, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(en1o2, OUTPUT);
pinMode(en2o2, OUTPUT);
pinMode(in1o2, OUTPUT);
pinMode(in2o2, OUTPUT);
pinMode(in3o2, OUTPUT);
pinMode(in4o2, OUTPUT);
}//close setup
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // Non-blocking
  int i;
        digitalWrite(13, true); // Flash a light to show received good message
  // Message with a good checksum received, dump it.
  for (i = 0; i < buflen; i++)
   Serial.print(buf[i]);//print received command
        if(buf[i] == '1')//if button 1 is pressed.... i.e.forward buton
        forward();//go forward
        Serial.println(" = forward");
    if(buf[i] == '2')//if button 2 is pressed.... i.e.back buton
        backward();//go backward
        Serial.println(" = backward");
        if(buf[i] == '3')//if button 3 is pressed.... i.e.left buton
        left();//go left
        Serial.println(" = left");
        if(buf[i] == '4')//if button 4 is pressed.... i.e.right buton
        right();//go right
        Serial.println(" = right");
        if(buf[i] == '5')//if button 5 is pressed.... i.e.stop buton
         stopMotor();//stop/brake
         Serial.println(" = stopped");
      Serial.print(" ");
  Serial.println("");
   }//close if
}//close loop
//set of functions
void forward()
  digitalWrite(en1,HIGH);
  digitalWrite(en2,HIGH);
  digitalWrite(en1o2,HIGH);
  digitalWrite(en2o2,HIGH);
  digitalWrite(in1,HIGH);
  digitalWrite(in1o2,HIGH);
  digitalWrite(in2,LOW);
  digitalWrite(in2o2,LOW);
  digitalWrite(in3,LOW);
  digitalWrite(in3o2,LOW);
  digitalWrite(in4,HIGH);
  digitalWrite(in4o2,HIGH);
void backward()
  digitalWrite(in1,LOW);
  digitalWrite(in1o2,LOW);
  digitalWrite(in2,HIGH);
  digitalWrite(in2o2,HIGH);
  digitalWrite(in3,HIGH);
  digitalWrite(in3o2,HIGH);
  digitalWrite(in4,LOW);
  digitalWrite(in4o2,LOW);
void left()
void right()
void stopMotor()
 //End Of Code
You need to look at the state change detection example. Send one value when a switch BECOMES pressed, and another when the switch BECOMES released.
Sweet. Thats what I was looking for. Thanks for the help. One more question. Do I add the state change to the transmitter code or the receiver code? Or do both sides need code to read the state change of the button?
Where does the state of the switch change?
Yeah, it was late when I asked that. It hit me as I was headed to bed. All is working as i want it to now. Thanks for the help.
