Hello there!
This is my first post.
I've been working with a family member on a small project, we needed to set the speed at which a solenoid works, and we found out that the arduino and do such a function.
What I need is someone to help me with the code.
We built this, but have nooo clue as to what the code should be.
We found this on a different website for a different setup.
http://learn.robotgeek.com/demo-code/124-arduino-solenoid-tutorial-button-demo.html
What do we change here, or, what should the code look like in order to recreate what the first video showed.
Controlling a Solenoid with Arduino
This demo shows how to control a solenoid using pushbuttons and a relay with
your Arduino compatable controller.
- The first button will hold the solenoid/relay on while it is held
- The second button will hold the solenoid/relay on for 2 seconds
The circuit:
* RobotGeek Pushbutton - Digital Pin 2
* RobotGeek Pushbutton - Digital Pin 4
* RobotGeek Relay - Digital Pin 7
Products Used in this demo:
- http://www.robotgeek.com/solenoids
- http://www.robotgeek.com/robotgeek-geekduino-sensor-kit
- http://www.robotgeek.com/robotGeek-pushbutton
- http://www.robotgeek.com/robotgeek-relay
// constants won't change. They're used here to set pin numbers:
const int button1Pin = 2; // the number of the pushbutton1 pin
const int button2Pin = 4; // the number of the pushbutton2 pin
const int relayPin = 7; // the number of the Relay pin
// variables will change:
int button1State = 0; // variable for reading the pushbutton status
int button2State = 0; // variable for reading the pushbutton status
// initialize the pushbutton pin as an input:
pinMode(button1Pin, INPUT);
pinMode(button2Pin, INPUT);
// initialize the relay pin as an output:
pinMode(relayPin, OUTPUT);
void loop(){
// read the state of the pushbutton values:
button1State = digitalRead(button1Pin);
button2State = digitalRead(button2Pin);
// check if the pushbutton1 is pressed.
// if it is we turn on the relay/solenoid
if (button1State == HIGH) {
// turn relay on:
digitalWrite(relayPin, HIGH);
// When we let go of the button, turn off the relay
else if ((button1State == LOW) && (digitalRead(relayPin) == HIGH)) {
// turn relay off
digitalWrite(relayPin, LOW);
// For the second button, we just activate the solenoid/relay for two seconds
if (button2State == HIGH) {
// turn relay on
delay(2000); // waits for 2 seconds
//turn relay off
Any help is greatly appreciated. I'm a newbie to this stuff myself, and i've been doing different code tutorials, I simply don't know what to do just yet.
