I will see if I can figure out a solution from the info sources that you have all pointed me to.
For reference the current code is below. (If this does not look right please let me know and I will post again.)
Loaded on a Nano controller it takes input from a hundatech touchscreen and sends to another controller and receives some sensor readings from the other controller which is then reflected on the screen.
I am sure that the code can be improved but I would like to get the crash issue sorted in the short term.
Thanks again for all the help.
// IIC Wire lcd Master Writer
// by martin xhli <http://www.hundatech.com>
const char EOPmarker = '>'; //This is the end of packet marker
char serialbuf[100]; //This gives the incoming serial some room. Change it if you want a longer incoming.
#define MAX_STRING_LEN 100
#include <LiquidCrystalDisplay.h>
#include <SoftwareSerial.h>
#include <string.h>
SoftwareSerial mySerial(6, 7); // RX, TX
const uint8_t String01[] = "Password ok!";
const uint8_t String02[] = "Password error!";
const uint8_t String03[] = "Error";
const uint8_t String04[] = "Input number ok!";
const uint8_t String05[] = "Input number error!";
//const uint8_t STRING[] = "TIME HERE PLEASE";
uint8_t identifier, cnt;
uint8_t cmd_buffer[CMD_MAX_SIZE];
uint8_t data_size;
uint8_t update_en;
uint8_t command_cmd;
uint8_t command_statu;
uint8_t command_length;
uint8_t page_Id_bk = 0;
uint8_t page_Id = 0;
uint8_t targe_Id = 0;
unsigned long startMillis;
unsigned long currentMillis;
const unsigned long period = 60000; // Timer for Date
unsigned long startMillis2;
unsigned long currentMillis2;
const unsigned long period2 = 5000; // Timer for time update on screen
int ContValue;
int ESP32R = 8;
LiquidCrystal TFTlcd(13);//RST pin13
int upper = 3700;
int lower = 3000;
int yold;
int v;
char* d;
char* t;
int z;
int y;
update_en = 0;
data_size = 0;
TFTlcd.queue_reset();
Serial.begin(57600);
Serial.flush();
Serial.println(F("Paint!"));
TFTlcd.begin();
mySerial.begin(57600);
mySerial.flush();
pinMode(ESP32R, OUTPUT);
digitalWrite(ESP32R, LOW);
digitalWrite(LED_BUILTIN, LOW);
delay(50);
digitalWrite(ESP32R, HIGH);
attachInterrupt(0, LcdIICInterrupt, FALLING); //Interrupt 0 is D2 PIN
TFTlcd.SetPage(1);//main page id is 1
void LcdIICInterrupt()
command_cmd = TFTlcd.I2C_Read();
TFTlcd.queue_push(command_cmd);
for (cnt = 0; cnt < 2; cnt++)
identifier = TFTlcd.I2C_Read();
TFTlcd.queue_push(identifier);
Serial.println(identifier, HEX);
command_statu = TFTlcd.I2C_Read();
TFTlcd.queue_push(command_statu);
command_length = TFTlcd.I2C_Read();
TFTlcd.queue_push(command_length);
if ((command_cmd == GET_EDIT_VALUE && command_statu == 0x6f) || (command_cmd == GET_TOUCH_EDIT_VALUE && command_statu == 0x6f))
for (cnt = 0; cnt < command_length; cnt++)
data_size = TFTlcd.queue_find_cmd(cmd_buffer, CMD_MAX_SIZE);
if (data_size > 0) //receive command
Serial.print("Data Size ");
Serial.println(data_size, HEX);
Serial.println(F("ProcessMessage"));
ProcessMessage((PCTRL_MSG)cmd_buffer, data_size);//command process
if (update_en)
Serial.println(F("UpdateUI"));
update_en = 0;
delay(100);
UpdateUI();
if (mySerial.available() > 0) { //makes sure something is ready to be read
static int bufpos = 0; //starts the buffer back at the first position in the incoming serial.read
char inchar = mySerial.read(); //assigns one byte (as serial.read()'s only input one byte at a time
if (inchar != EOPmarker) { //if the incoming character is not the byte that is the incoming package ender
serialbuf[bufpos] = inchar; //the buffer position in the array get assigned to the current read
bufpos++; //once that has happend the buffer advances, doing this over and over again until the end of package marker is read.
else { //once the end of package marker has been read
serialbuf[bufpos] = 0; //restart the buff
bufpos = 0; //restart the position of the buff
// Serial.println("parseData");
// Serial.println(serialbuf);
char * pch; // pointer to tokens
// Serial.print("Splitting string ");
// Serial.print(serialbuf);
// Serial.println(" into tokens:");
pch = strtok (serialbuf, ",/}"); // get first token
while (pch != NULL)
int g = 999;
// Serial.print("string found ");
// Serial.println(pch); // print it
int x = atoi(pch);
if (x == 40) {
TFTlcd.SetPage(1);
TFTlcd.SetBarGaugeValue(1, 91, v);
TFTlcd.SetLableValue(1, 67, (unsigned char *)d);
TFTlcd.SetLableValue(1, 68, (unsigned char *)t);
else if (x == 8 || x == 13) {
else if (x == 9) {
pch = strtok (NULL, ",/}"); // get next token
y = atoi(pch);
// Serial.println(y != yold);
if (y == 1 && y != yold) {
TFTlcd.SetProgressbarValue(1, 44, 100);
yold = y;
else if (y == 0 && y != yold) {
TFTlcd.SetProgressbarValue(1, 44, 0);
yold = y;
z = atoi(pch);
v = 100 - (z / 41);
TFTlcd.SetNumberValue(1, 45, v);
d = pch;
currentMillis = millis();
if (currentMillis - startMillis >= period) {
startMillis = millis();
t = pch;
currentMillis2 = millis();
if (currentMillis2 - startMillis2 >= period2) {
startMillis2 = millis();
char* subStr (char* input_string, char *separator, int segment_number) {
char *act, *sub, *ptr;
static char copy[MAX_STRING_LEN];
int i;
strcpy(copy, input_string);
for (i = 1, act = copy; i <= segment_number; i++, act = NULL) {
sub = strtok_r(act, separator, &ptr);
if (sub == NULL) break;
return sub;
void ProcessMessage( PCTRL_MSG msg, uint16_t dataSize )
uint8_t cmd_type = msg->cmd_type;
uint8_t control_id = msg->control_id;
uint8_t page_id = msg->page_id;
uint8_t _status = msg->status;
uint8_t key_type = msg->key_type;
uint8_t key_value = msg->key_value;
switch (cmd_type)
case NOTIFY_TOUCH_BUTTON:
NotifyTouchButton(page_id, control_id, _status, key_type, key_value);
default:
void UpdateUI()
int i;
int value;
Serial.print("page_Id = ");
Serial.println(page_Id);
if (page_Id == Text_PAGE)
TFTlcd.SetNumberValue(page_Id, 19, 20);
TFTlcd.SetNumberValue(page_Id, 20, 21);
TFTlcd.SetNumberValue(page_Id, 21, 28);
TFTlcd.SetNumberValue(page_Id, 22, 35);
TFTlcd.SetNumberValue(page_Id, 23, 46);
TFTlcd.SetNumberValue(page_Id, 24, 58);
TFTlcd.SetLableValue(page_Id, 16, (unsigned char *)String03);
TFTlcd.SetLableValue(page_Id, 17, (unsigned char *)String03);
TFTlcd.SetLableValue(page_Id, 18, (unsigned char *)String03);
void NotifyTouchButton(uint8_t page_id, uint8_t control_id, uint8_t state, uint8_t type, uint8_t value)
//TODO:
ContValue = control_id;
mySerial.write(ContValue);
Serial.print("Contvalue sent = ");
Serial.println(ContValue);
if (type == CHANGE_PAGE && state == KEY_RELEASE)
page_Id = value;
update_en = 1;
Serial.println("CHANGE ?? ");
//UpdateUI();
else if (type == ENTER && state == KEY_RELEASE)
targe_Id = value;//targe Edit Id
TFTlcd.GetEditValue(page_Id, targe_Id);
Serial.println("ENTER ?? ");
else if (type == CHAR)
Serial.println("CHAR ?? ");
else if (type == UPLOAD_CONTROL_ID)
Serial.println("UPLOAD ?? ");
else if (type == CLEAR)
Serial.println("CLEAR ?? ");
if (ContValue == 40) {
else if (ContValue == 8 || ContValue == 13)
yold = 1;
ContValue = 0;
