Need help with code to make an on/off switch work on my shield
Hello,
I am programming some lights and have a shield with 2 slide on, off switches.
The lights are only going to be on for 90 seconds at a time and are running on batteries.
I have all of the code to run the lights the way I need, but right now, they just start when I plug in the power source. I would rather be able to have them all plugged in, then flip a switch.
I am VERY novice.
This is the shield I have, with the switch.
http://shopping.coolneon.com/Store-Display-name
There are 2 switches available but I only need 1 to do anything, right now.
From my research, the switches are pin 6 and pin 7. I am not particular on which one is the on off.
Does anyone know the additional code I need for this? This is the sketch, as it exists now. (thanks to people on this forum :slight_smile:
#define PIN 11
Adafruit_NeoPixel strip = Adafruit_NeoPixel(100, PIN, NEO_GRB + NEO_KHZ800);
#define COLOR(r,g,b) ( (uint32_t)r << 16) | ((uint32_t)g <<  8) | b
uint32_t BLACK = COLOR(0,0,0);
uint32_t WHITE = COLOR(255,255,255);
uint32_t RED = COLOR(255,0,0);
uint32_t GREEN = COLOR(0,255,0);
uint32_t BLUE = COLOR(0,0,255);
uint32_t PURPLE = COLOR(51,0,102);
uint32_t PINK = COLOR(204,0,204);
uint32_t YELLOW = COLOR(255,198,7);
uint32_t Wheel(byte WheelPos)
  if(WheelPos < 85)
    return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  else if(WheelPos < 170)
    WheelPos -= 85;
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
    WheelPos -= 170;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
class Pattern
  public:
  virtual void Init(void)
  virtual void Run(long time)
  static void SetAll (uint32_t color)
    for (uint16_t i=0; i<strip.numPixels(); i++) {
        strip.setPixelColor(i, color);
    strip.show();
  static void SetSomeLeds (uint32_t color, int numberLeds)
    for (uint16_t i=0; i<numberLeds; i++) {
    strip.show();
class Color : public Pattern
  public:
  uint32_t m_color;
  Color (uint32_t color)
     m_color = color;
  void Init (void)
    Pattern::SetAll(m_color);
class RGB : public Color
  public:
  RGB (byte red, byte green, byte blue) :
    Color (COLOR (red, green, blue))
class FlashyRainbow : public Pattern
  byte base;
  void Run (long elapsed)
    uint16_t j;
    elapsed = elapsed % 400;
    if (elapsed < 200)
      for(j=0; j<strip.numPixels(); j++)
        int val = elapsed + j * 256 / strip.numPixels();
        strip.setPixelColor(j, Wheel(val % 256 ));
      strip.show();
      Pattern::SetAll(BLACK);
class FlashyYellow: public Pattern
  void Init (void)
    Pattern::SetAll(YELLOW);
    if (elapsed < 200)
typedef struct {
  int time;
  Pattern *pattern;
} Effect;
Effect effects[] = {
  {6250, new FlashyRainbow()}, // 10 seconds of flashy rainbow
  {500, new Color(RED)},      // 1 seconds red
  {500, new Color(GREEN)},    // 1 seconds green
  {1500, new Color(PURPLE)},   // 1 seconds purple
  {500, new Color(PINK)},     // 1 seconds pink
  {500, new Color(BLUE)},     // 1 seconds blue
  {4000, new Color(YELLOW)},   // 3 seconds yellow
  {4500, new FlashyRainbow()}, // 6 seconds of flashy rainbow
  {1675, new Color(RED)},      // 2 seconds red
  {2750, new Color(GREEN)},    // 2 seconds green
  {950, new Color(RED)},      // 1 seconds red
  {2900, new Color(GREEN)},    // 3 seconds green
  {1000, new Color(RED)},      // 1 seconds red
  {2500, new RGB(0,255,0)},    // 3 seconds green
  {1000, new RGB(255,0,0)},    // 1 seconds red
  {3000, new Color(GREEN)},    // 3 seconds green
  {5000, new FlashyYellow()}, // 11 seconds of flashy yellow
  {5000, new FlashyYellow()}, // 10 seconds of flashy yellow
  {3000, new FlashyRainbow()}, // 10 seconds of flashy rainbow
  {0, NULL}
class EffectController
  Effect *m_effects;
  int m_index = 0;
  long m_start;
  public:
  EffectController (Effect effects [])
    m_effects = effects;
  void Start (void)
    Serial.print ("start ");
    strip.begin();
    strip.show(); // Initialize all pixels to 'off'
    m_index = 0;
  void ShowStatus (void)
      Serial.print ("time ");
      Serial.print ((long)(millis()-m_start));
      Serial.print (" track ");
      Serial.print (m_index);
  void Run (void)
    long elapsed;
    //long this_time = m_effects[m_index].time * 1000;
    long this_time = m_effects[m_index].time;
    if (m_index == 0)
      m_start = millis();
    if (this_time > 0)
      ShowStatus();
      long track_start = millis();
      m_effects[m_index].pattern->Init();
      do
         elapsed =  millis() - track_start;
         m_effects[m_index].pattern->Run(elapsed);
      } while (elapsed < this_time);
      m_index++;
      if (m_effects[m_index].time == 0)
        // finished
        Serial.print (" finished");
        Pattern::SetAll(COLOR(0,0,0));
EffectController controller (effects);
  int j;
  Pattern::SetSomeLeds (RED, 1);
  for (j=5; j>0; j--)
    Pattern::SetSomeLeds (GREEN, j);
    delay (1000);
  controller.Start();
  controller.Run();
Please edit your post and add code tags around the code.
Type
** **[code]** **
before the code
Type
** **[/code]** **
after the code
So it looks like
your code here
It makes it easier to read and copy and it prevents possibly corruption by the forum software.
Last 2 lines in setup()
pinMode(6,INPUT_PULLUP);
while(digitalRead(6)); // processor will loop here until button on pin 6 is pressed
HowToPostCode
