Need help with coding
ok here is the code
I need help combining them. I want the sound sensor to pick up signal that activates my motor.
Code for the sound sensor:
const int soundPin = A0; //sound sensor attach to A0
int threshold = 600; //Set minimum threshold for LED lit
  pinMode(ledPin, OUTPUT); //set pin13 as OUTPUT
  Serial.begin(9600); //initialize serial
  int value = analogRead(soundPin);//read the value of A0
  Serial.println(value);//print the value
  if (value > threshold) //if the value is greater than 600
    digitalWrite(ledPin, HIGH); //turn on the led
    delay(200);//delay 200ms
    digitalWrite(ledPin, LOW); //turn off the led
}````Preformatted text`
motor sensor:
// C++ code
#include <Servo.h>
int i = 0;
int postision = 0;
int j = 0;
Servo servo_0;
Servo servo_9;
  servo_0.attach(0, 500, 2500);
  servo_9.attach(9, 500, 2500);
  postision = 0;
  for (i = 1; i <= 90; i += 1) {
    servo_0.write(postision);
    delay(50); // Wait for 50 millisecond(s)
  for (postision = 90; postision >= 1; postision -= 1) {
    servo_9.write(postision);
Topics relating to the same code merged
@paxid do not cross post what is actually the same question in different topics otherwise you run the risk of a timeout from the forum
as a program can do more complex things than two combined lego-bricks.
Programming is more complex than lego-bricks.
The first combining you can do is combine reading first, with second, third, fourth,.... page of a programming tutorial like this:
Arduino Programming Course
best regards Stefan
